Coś zrobiłem i nie wiem co ale Node Red postanowił przestać działać
W logach mam to:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 10.3.4
System: Home Assistant OS 7.2 (aarch64 / raspberrypi3-64)
Home Assistant Core: 2021.12.10
Home Assistant Supervisor: 2021.12.2
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing...
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
patching file nodes/ui_base.html
Hunk #1 succeeded at 1162 (offset 631 lines).
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /config/node-red/node_modules/dayjs
npm ERR! dest /config/node-red/node_modules/.dayjs-SLjun9vU
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/config/node-red/node_modules/dayjs' -> '/config/node-red/node_modules/.dayjs-SLjun9vU'
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-01-25T17_30_08_823Z-debug.log
[18:30:09] FATAL: Failed un-installing conflicting packages
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Co mogę zrobić już go przeinstalowałem i nic to nie dało
nie diała sudo też nie nawet apt install ni nie działa czy coś mam źle ustawione?
