SetOption19 1
04:40:05 CMD: SetOption19 1
04:40:05 MQT: sypialnia_lampka/stat/RESULT = {"SetOption19":"ON"}
04:40:06 MQT: homeassistant/switch/9A55A3_RL_1/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_1/config = {"name":"Sonoff","cmd_t":"~cmnd/POWER","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Aktywny","pl_not_avail":"Nieaktywny","uniq_id":"9A55A3_LI_1","device":{"identifiers":["9A55A3"],"connections":[["mac","70:03:9F:9A:55:A3"]]},"~":"sypialnia_lampka/"} (Zachowane)
04:40:06 MQT: homeassistant/switch/9A55A3_RL_2/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_2/config = (Zachowane)
04:40:06 MQT: homeassistant/switch/9A55A3_RL_3/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_3/config = (Zachowane)
04:40:06 MQT: homeassistant/switch/9A55A3_RL_4/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_4/config = (Zachowane)
04:40:06 MQT: homeassistant/switch/9A55A3_RL_5/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_5/config = (Zachowane)
04:40:06 MQT: homeassistant/switch/9A55A3_RL_6/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_6/config = (Zachowane)
04:40:06 MQT: homeassistant/switch/9A55A3_RL_7/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_7/config = (Zachowane)
04:40:06 MQT: homeassistant/switch/9A55A3_RL_8/config = (Zachowane)
04:40:06 MQT: homeassistant/light/9A55A3_LI_8/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_BTN_1/config = {"name":"Sonoff Button1","stat_t":"~stat/RESULT","value_template":"{{value_json.BUTTON1}}","pl_on":"TOGGLE","avty_t":"~tele/LWT","pl_avail":"Aktywny","pl_not_avail":"Nieaktywny","uniq_id":"9A55A3_BTN_1","device":{"identifiers":["9A55A3"],"connections":[["mac","70:03:9F:9A:55:A3"]]},"~":"sypialnia_lampka/","off_delay":1} (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_BTN_2/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_BTN_3/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_BTN_4/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_1/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_2/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_3/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_4/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_5/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_6/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_7/config = (Zachowane)
04:40:06 MQT: homeassistant/binary_sensor/9A55A3_SW_8/config = (Zachowane)
04:40:06 MQT: homeassistant/sensor/9A55A3_status/config = {"name":"Sonoff status","stat_t":"~HASS_STATE","avty_t":"~LWT","pl_avail":"Aktywny","pl_not_avail":"Nieaktywny","json_attributes_topic":"~HASS_STATE","unit_of_meas":" ","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"9A55A3_status","device":{"identifiers":["9A55A3"],"connections":[["mac","70:03:9F:9A:55:A3"]],"name":"Sonoff","model":"Sonoff Basic","sw_version":"6.7.1(sonoff)","manufacturer":"Tasmota"},"~":"sypialnia_lampk ... (Zachowane)
SetOption30 1
04:41:32 CMD: SetOption30 1
04:41:32 MQT: sypialnia_lampka/stat/RESULT = {"SetOption30":"ON"}
04:41:33 MQT: homeassistant/switch/9A55A3_RL_1/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_1/config = {"name":"Sonoff","cmd_t":"~cmnd/POWER","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Aktywny","pl_not_avail":"Nieaktywny","uniq_id":"9A55A3_LI_1","device":{"identifiers":["9A55A3"],"connections":[["mac","70:03:9F:9A:55:A3"]]},"~":"sypialnia_lampka/"} (Zachowane)
04:41:33 MQT: homeassistant/switch/9A55A3_RL_2/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_2/config = (Zachowane)
04:41:33 MQT: homeassistant/switch/9A55A3_RL_3/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_3/config = (Zachowane)
04:41:33 MQT: homeassistant/switch/9A55A3_RL_4/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_4/config = (Zachowane)
04:41:33 MQT: homeassistant/switch/9A55A3_RL_5/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_5/config = (Zachowane)
04:41:33 MQT: homeassistant/switch/9A55A3_RL_6/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_6/config = (Zachowane)
04:41:33 MQT: homeassistant/switch/9A55A3_RL_7/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_7/config = (Zachowane)
04:41:33 MQT: homeassistant/switch/9A55A3_RL_8/config = (Zachowane)
04:41:33 MQT: homeassistant/light/9A55A3_LI_8/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_BTN_1/config = {"name":"Sonoff Button1","stat_t":"~stat/RESULT","value_template":"{{value_json.BUTTON1}}","pl_on":"TOGGLE","avty_t":"~tele/LWT","pl_avail":"Aktywny","pl_not_avail":"Nieaktywny","uniq_id":"9A55A3_BTN_1","device":{"identifiers":["9A55A3"],"connections":[["mac","70:03:9F:9A:55:A3"]]},"~":"sypialnia_lampka/","off_delay":1} (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_BTN_2/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_BTN_3/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_BTN_4/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_1/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_2/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_3/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_4/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_5/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_6/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_7/config = (Zachowane)
04:41:33 MQT: homeassistant/binary_sensor/9A55A3_SW_8/config = (Zachowane)
04:41:33 MQT: homeassistant/sensor/9A55A3_status/config = {"name":"Sonoff status","stat_t":"~HASS_STATE","avty_t":"~LWT","pl_avail":"Aktywny","pl_not_avail":"Nieaktywny","json_attributes_topic":"~HASS_STATE","unit_of_meas":" ","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"9A55A3_status","device":{"identifiers":["9A55A3"],"connections":[["mac","70:03:9F:9A:55:A3"]],"name":"Sonoff","model":"Sonoff Basic","sw_version":"6.7.1(sonoff)","manufacturer":"Tasmota"},"~":"sypialnia_lampk ... (Zachowane)
