Sterownik pompy ciepła power_consumption
posiadam sterownik pompy ciepła, który działa z apką Tuya. Zintegrowałem go z HA poprzez chmurę.
W apce mam tylko 3 opcje włącz wyłącz, temperatura CO i ustawienia krzywej.
ostatnio grzebiąc w HA znalazłem coś takiego (diagnostyka TUYA)
        "id": "bfb118994302dd9469o5vi",
        "name": "Inteligentna pompa ciep\u0142a",
        "category": "znrb",
        "product_id": "vfaiykidx9qaxrxn",
        "product_name": "Intelligent Heat Pump",
        "online": true,
        "sub": false,
        "time_zone": "+01:00",
        "active_time": "2025-01-22T20:28:00+00:00",
        "create_time": "2025-01-22T20:28:00+00:00",
        "update_time": "2025-01-22T20:28:00+00:00",
        "function": {
          "switch": {
            "type": "Boolean",
            "value": {}
          "mode": {
            "type": "Enum",
            "value": {
              "range": [
                "cold",
                "heating"
          "temp_set": {
            "type": "Integer",
            "value": {
              "unit": "\u2103",
              "min": 5,
              "max": 75,
              "scale": 0,
              "step": 1
          "water_set": {
            "type": "Integer",
            "value": {
              "unit": "L",
              "min": 0,
              "max": 1,
              "scale": 0,
              "step": 1
        "status_range": {
          "switch": {
            "type": "Boolean",
            "value": {}
          "mode": {
            "type": "Enum",
            "value": {
              "range": [
                "cold",
                "heating"
          "temp_set": {
            "type": "Integer",
            "value": {
              "unit": "\u2103",
              "min": 5,
              "max": 75,
              "scale": 0,
              "step": 1
          "water_set": {
            "type": "Integer",
            "value": {
              "unit": "L",
              "min": 0,
              "max": 1,
              "scale": 0,
              "step": 1
          "power_consumption": {
            "type": "Integer",
            "value": {
              "unit": "kW\u00b7h",
              "min": 0,
              "max": 200000,
              "scale": 2,
              "step": 1
          "temp_top": {
            "type": "Integer",
            "value": {
              "unit": "\u2103",
              "min": -50,
              "max": 150,
              "scale": 0,
              "step": 1
          "temp_bottom": {
            "type": "Integer",
            "value": {
              "unit": "\u2103",
              "min": -50,
              "max": 150,
              "scale": 0,
              "step": 1
          "defrost_state": {
            "type": "Boolean",
            "value": {}
        "status": {
          "switch": true,
          "mode": "heating_and_hot_water",
          "temp_set": 45,
          "water_set": 1,
          "power_consumption": 0,
          "temp_top": 38,
          "temp_bottom": 44,
          "defrost_state": false
        "home_assistant": {
          "name_by_user": null,
          "disabled": false,
          "disabled_by": null,
          "entities": [
              "disabled": false,
              "entity_category": null,
              "device_class": null,
              "original_device_class": null,
              "icon": null,
              "original_icon": null,
              "unit_of_measurement": null,
              "state": {
                "entity_id": "number.inteligentna_pompa_ciepla_temperatura",
                "state": "45.0",
                "attributes": {
                  "min": 5.0,
                  "max": 75.0,
                  "step": 1.0,
                  "mode": "auto",
                  "friendly_name": "Inteligentna pompa ciep\u0142a Temperatura"
                "last_changed": "2025-02-20T08:46:12.214000+00:00",
                "last_reported": "2025-02-20T08:46:12.214000+00:00",
                "last_updated": "2025-02-20T08:46:12.214000+00:00"
              "disabled": false,
              "icon": null,
              "state": {
                "entity_id": "switch.inteligentna_pompa_ciepla_switch",
                "state": "on",
                "attributes": {
                  "friendly_name": "Inteligentna pompa ciep\u0142a Switch"
                "last_changed": "2025-02-20T08:46:12.242596+00:00",
                "last_reported": "2025-02-20T08:46:12.242596+00:00",
                "last_updated": "2025-02-20T08:46:12.242596+00:00"
        "set_up": true,
        "support_local": true
Czy jestem w stanie z urządzenia wydobyć power_consumption.
Dokładnie gdzie to znalazłeś i czy się aktualizuje?
HA → Ustawienia → urządzenia i usługi → Tuya
Pobierz diagnostykę.
W stanach niestety tego nie widzę poza
