Witajcie!
Mam HA zainstalowanego na dockerze, działał, aktualizował się - miodzio. Ale dziś musiałem restartować serwer i … coś się wykrzaczyło i nie do końca wiem co
Jako że dockera i te okolice jeszcze średnio ogarniam, to napiszę co wiem.
W logach widzę takie coś:
ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /os/info -
ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /info -
ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /refresh_updates request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /backups request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /backups -
ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /host/info -
ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /supervisor/info -
Z tego co widzę próbuje się dobić do 172.30.32.2. IP się nie pinguje - wygląda jakby jakaś usługa się nie podniosła.
W Integracjach przy Supervisor jest napis “Próbuję ponownie skonfigurować: Error on Supervisor API:” i podpięte pod niego brooker Mosquito, File Editor - nie działają.
Poszukując tego IP znalazłem takie coś w configu:
docker inspect 36d1a00ad7fc | grep "172.30.32.2"
"supervisor:172.30.32.2"
"HASSIO=172.30.32.2",
"SUPERVISOR=172.30.32.2",
No i tu się zatrzymałem. Gdzie szukać potencjalnego błędu?
EDIT: dla potomnych - błąd typu HGW. Po przekilkaniu się przez dziesiątki podobnych zgłoszeń które nic nie dały, finalnie pomogło przeinstalowanie Supervisora:
docker pull homeassistant/amd64-hassio-supervisor
oraz zrestartowanie HA.
