root@debian12:~# wget https://github.com/home-assistant/os-agent/releases/download/1.6.0/os-agent_1.6.0_linux_x86_64.deb
--2024-05-12 10:40:24-- https://github.com/home-assistant/os-agent/releases/download/1.6.0/os-agent_1.6.0_linux_x86_64.deb
Translacja github.com (github.com)... nieudane: Odwzorowanie nazwy jest chwilowo niemożliwe.
wget: nie udało się rozwiązać adresu hosta `github.com'
Proszę o wskazówki, ewentualnie jakiś aktualny poradnik.
Serwer podpięty kablem do routera. Internet jest.
Jeżeli problem jest z serwerem DNS, to jak się za to zabrać ?
Tak mam wpisane w: etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug enp4s0
iface enp4s0 inet static
address 192.168.1.140/24
gateway 192.168.1.1
# dns-* options are implemented by the resolvconf package, if installed
dns-nameservers 192.168.1.1
dns-search debian12
ping z maszyny do DNS 8.8.8.8 przechodzi.
tak samo jest komunikacja z routerem.
Maszyna jest podłączona kablem, ale przez switch.
W cat /etc/resolv.conf mam takiego logi:
root@debian12:~# cat /etc/resolv.conf
# This is /run/systemd/resolve/stub-resolv.conf managed by man:systemd-resolved(8).
# Do not edit.
# This file might be symlinked as /etc/resolv.conf. If you're looking at
# /etc/resolv.conf and seeing this text, you have followed the symlink.
# This is a dynamic resolv.conf file for connecting local clients to the
# internal DNS stub resolver of systemd-resolved. This file lists all
# configured search domains.
# Run "resolvectl status" to see details about the uplink DNS servers
# currently in use.
# Third party programs should typically not access this file directly, but only
# through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a
# different way, replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 127.0.0.53
options edns0 trust-ad
search DOMAINS
Proste polecenie do weryfikacji działania DNSa na stacji roboczej:
nslookup wp.pl
To weryfikuje “połączenia” do internetu ale nie poprawność konfiguracji sieciowej, np. DNSa, lepiej od razu użyć ping wp.pl i za pomocą jednego polecenia weryfikujesz kilka rzeczy na raz. Na podstawie odpowiedzi wiesz co dziala albo nie.
Konfigurowanie pakietu homeassistant-supervised (1.7.0) ...
[info] Reload systemd
[info] Restarting NetworkManager
[info] Enable systemd-resolved
[info] Restarting systemd-resolved
[info] Set up systemd-journal-gatewayd socket file
[info] Enable systemd-journal-gatewayd
[info] Start nfs-utils.service
[info] Restarting docker service
ping: checkonline.home-assistant.io: Odwzorowanie nazwy jest chwilowo niemożliwe
[info] Waiting for checkonline.home-assistant.io - network interface might be down...
Nie wiem dlaczego, ale wysypały się wszystkie ustawienia sieciowe i to było powodem.
Wprowadziłem wszystko z palca i poszło.
Zobaczę co dalej.
Jest dobrze, wszystko się zainstalowało. Dzięki za pomoc.
Teraz zostaje kwestia wgrania kopii i pewnie uzupełnienia integracji, dodatków itp.
Nie mam pewności czy dodatki typu Influxdb, grafana itp. zainstalują się z kopii ?
Ale to będę sprawdzał w tygodniu najbliższym.
EDIT:
Kopia zainstalowana, wszystko ładnie się uzupełniło. Także instalacja od podstaw tego systemu zaliczona, przybyło troszkę doświadczenia.
Za jakiś czas trzeba będzie spróbować wgrania innego rodzaju systemu.
