Jest wątek o tym na forum
a wracając do problemu ? Narazie jednak zostane wykorzystując Synology którego mam.
Zmiana kontrolera USB z 3.0 na 2.0 nie przynosi poprawy
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[22:25:40] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[22:25:41] INFO: MQTT available, fetching server detail ...
[22:25:41] INFO: Previous config file found, checking backup
[22:25:41] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[22:25:41] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:25:41] INFO: Zigbee Herdsman debug logging enabled
[22:25:42] INFO: Handing over control to Zigbee2mqtt Core ...
> zigbee2mqtt@1.21.2 start
> node index.js
2021-10-10T20:25:47.278Z zigbee-herdsman:adapter Failed to validate path: 'Error: spawn udevadm ENOENT'
2021-10-10T20:25:47.284Z zigbee-herdsman:deconz:driver Set delay to 0
CREATED DECONZ ADAPTER
2021-10-10T20:25:47.286Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,14,13,15,1,6,8,9,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2428263-if00","adapter":"deconz"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2021-10-10T20:25:47.287Z zigbee-herdsman:deconz:driver Opening with /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2428263-if00
2021-10-10T20:25:47.298Z zigbee-herdsman:deconz:driver Serialport opened
2021-10-10T20:25:47.300Z zigbee-herdsman:controller:log Started with result 'resumed'
2021-10-10T20:25:47.300Z zigbee-herdsman:controller:log Injected database: true, adapter: true
2021-10-10T20:25:47.306Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 1 paramId: 1
2021-10-10T20:25:50.288Z zigbee-herdsman:deconz:adapter checking coordinator simple descriptor
2021-10-10T20:25:50.291Z zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0x0 EP:0 SeqNr. 2 request id: 1
2021-10-10T20:25:50.300Z zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 79 srcAddr: 0x0 destAddr: 0x0 profile id: 0x0 cluster id: 0x8004 lqi: 221
2021-10-10T20:25:50.300Z zigbee-herdsman:deconz:frameParser response payload: 1,0,0,0,24,1,4,1,5,0,1,4,0,0,10,0,25,0,1,5,4,1,0,32,0,0,5,2,5
2021-10-10T20:25:50.301Z zigbee-herdsman:deconz:adapter resolve data request without a transSeq Nr.
2021-10-10T20:25:50.301Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:25:50.302Z zigbee-herdsman:deconz:adapter RECEIVING SIMPLE_DESCRIPTOR - addr: 0x0 EP:1 inClusters: 0,10,25,1281 outClusters: 1,32,1280,1282
2021-10-10T20:25:50.302Z zigbee-herdsman:deconz:adapter EP: 1
2021-10-10T20:25:50.302Z zigbee-herdsman:deconz:adapter profile ID: 260
2021-10-10T20:25:50.302Z zigbee-herdsman:deconz:adapter device ID: 5
2021-10-10T20:25:50.302Z zigbee-herdsman:deconz:adapter input cluster: 0x0
2021-10-10T20:25:50.302Z zigbee-herdsman:deconz:adapter input cluster: 0xa
2021-10-10T20:25:50.302Z zigbee-herdsman:deconz:adapter input cluster: 0x19
2021-10-10T20:25:50.303Z zigbee-herdsman:deconz:adapter input cluster: 0x501
2021-10-10T20:25:50.303Z zigbee-herdsman:deconz:adapter output cluster: 0x1
2021-10-10T20:25:50.303Z zigbee-herdsman:deconz:adapter output cluster: 0x20
2021-10-10T20:25:50.303Z zigbee-herdsman:deconz:adapter output cluster: 0x500
2021-10-10T20:25:50.303Z zigbee-herdsman:deconz:adapter output cluster: 0x502
2021-10-10T20:25:50.304Z zigbee-herdsman:deconz:driver query aps data confirm
2021-10-10T20:25:50.309Z zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 3
2021-10-10T20:25:50.313Z zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - destAddr: 0x0 request id: 1 confirm status: 0
2021-10-10T20:25:50.313Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:25:57.307Z zigbee-herdsman:deconz:driver Timeout for request - CMD: 0xa seqNr: 1
Zigbee2MQTT:error 2021-10-10 22:25:57: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-10-10 22:25:57: Failed to start zigbee
Zigbee2MQTT:error 2021-10-10 22:25:57: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-10-10 22:25:57: Exiting...
Zigbee2MQTT:error 2021-10-10 22:25:57: undefined
Nie wiem co dalej
EDIT:
Przy uruchomieniu zigbee2mqtt z odmontowanym conbee2 startuje z błędem że brak urządzenia, jednak jesli zamontuje conbee do maszyny wirtualnej bez zatrzymywania addona - teoretycznie uruchamia się. Jednak przy zaniku prądu i uruchomieniu ponownie to nie jest w pełni autonomiczne rozwiązanie…
2021-10-10T20:28:38.408Z zigbee-herdsman:deconz:adapter output cluster: 0x20
2021-10-10T20:28:38.408Z zigbee-herdsman:deconz:adapter output cluster: 0x500
2021-10-10T20:28:38.408Z zigbee-herdsman:deconz:adapter output cluster: 0x502
2021-10-10T20:28:38.409Z zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 18
2021-10-10T20:28:42.460Z zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101010
2021-10-10T20:28:42.460Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:42.461Z zigbee-herdsman:deconz:driver query aps data indication
2021-10-10T20:28:42.466Z zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 19
2021-10-10T20:28:42.469Z zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 19 srcAddr: 0x347f destAddr: 0x0 profile id: 0x104 cluster id: 0xef00 lqi: 255
2021-10-10T20:28:42.469Z zigbee-herdsman:deconz:frameParser response payload: 8,3,11,36,0
2021-10-10T20:28:42.472Z zigbee-herdsman:deconz:adapter resolve data request with transSeq Nr.: 3
2021-10-10T20:28:42.475Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":3,"manufacturerCode":null,"commandIdentifier":11},"Payload":{"cmdId":36,"statusCode":0},"Command":{"ID":11,"name":"defaultRsp","parameters":[{"name":"cmdId","type":32},{"name":"statusCode","type":32}]}},"address":13439,"endpoint":1,"linkquality":255,"groupID":null,"wasBroadcast":false,"destinationEndpoint":1}'
2021-10-10T20:28:42.477Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:42.478Z zigbee-herdsman:deconz:adapter response received
2021-10-10T20:28:42.479Z zigbee-herdsman:controller:endpoint Command 0x847127fffe10050a/1 manuSpecificTuya.setTime({"payloadSize":8,"payload":[97,99,76,250,97,99,105,26]}, {"sendWhenActive":false,"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false})
2021-10-10T20:28:42.479Z zigbee-herdsman:deconz:adapter zclFrame.payload:
2021-10-10T20:28:42.480Z zigbee-herdsman:deconz:adapter {
payloadSize: 8,
payload: [
97, 99, 76, 250,
97, 99, 105, 26
2021-10-10T20:28:42.481Z zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0xef16 EP:1 SeqNr. 20 request id: 5
2021-10-10T20:28:42.500Z zigbee-herdsman:deconz:frameParser DATA_REQUEST RESPONSE - request id: 5 status: 0
2021-10-10T20:28:42.500Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:45.381Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 21
2021-10-10T20:28:45.385Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-10-10T20:28:45.386Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:46.452Z zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10100110
2021-10-10T20:28:46.452Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:46.455Z zigbee-herdsman:deconz:driver query aps data confirm
2021-10-10T20:28:46.461Z zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 22
2021-10-10T20:28:46.463Z zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - destAddr: 0xef16 request id: 5 confirm status: 0
2021-10-10T20:28:46.463Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:46.464Z zigbee-herdsman:deconz:adapter sendZclFrameToEndpoint - message send with transSeq Nr.: 4
2021-10-10T20:28:51.503Z zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101010
2021-10-10T20:28:51.504Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:51.506Z zigbee-herdsman:deconz:driver query aps data indication
2021-10-10T20:28:51.558Z zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 23
2021-10-10T20:28:51.567Z zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 23 srcAddr: 0xef16 destAddr: 0x0 profile id: 0x104 cluster id: 0xef00 lqi: 255
2021-10-10T20:28:51.567Z zigbee-herdsman:deconz:frameParser response payload: 8,4,11,36,0
2021-10-10T20:28:51.567Z zigbee-herdsman:deconz:adapter resolve data request with transSeq Nr.: 4
2021-10-10T20:28:51.568Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":4,"manufacturerCode":null,"commandIdentifier":11},"Payload":{"cmdId":36,"statusCode":0},"Command":{"ID":11,"name":"defaultRsp","parameters":[{"name":"cmdId","type":32},{"name":"statusCode","type":32}]}},"address":61206,"endpoint":1,"linkquality":255,"groupID":null,"wasBroadcast":false,"destinationEndpoint":1}'
2021-10-10T20:28:51.569Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:51.570Z zigbee-herdsman:deconz:adapter response received
2021-10-10T20:28:51.571Z zigbee-herdsman:controller:endpoint Command 0x847127fffe110b03/1 manuSpecificTuya.setTime({"payloadSize":8,"payload":[97,99,77,4,97,99,105,36]}, {"sendWhenActive":false,"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false})
2021-10-10T20:28:51.572Z zigbee-herdsman:deconz:adapter zclFrame.payload:
2021-10-10T20:28:51.572Z zigbee-herdsman:deconz:adapter {
payloadSize: 8,
payload: [
97, 99, 77, 4,
97, 99, 105, 36
2021-10-10T20:28:51.573Z zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0xcdec EP:1 SeqNr. 24 request id: 6
2021-10-10T20:28:51.581Z zigbee-herdsman:deconz:frameParser DATA_REQUEST RESPONSE - request id: 6 status: 0
2021-10-10T20:28:51.581Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:55.382Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 25
2021-10-10T20:28:55.386Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-10-10T20:28:55.386Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:55.428Z zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10100110
2021-10-10T20:28:55.429Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:55.430Z zigbee-herdsman:deconz:driver query aps data confirm
2021-10-10T20:28:55.436Z zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 26
2021-10-10T20:28:55.439Z zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - destAddr: 0xcdec request id: 6 confirm status: 0
2021-10-10T20:28:55.439Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:28:55.439Z zigbee-herdsman:deconz:adapter sendZclFrameToEndpoint - message send with transSeq Nr.: 5
2021-10-10T20:29:00.477Z zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101010
2021-10-10T20:29:00.477Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:29:00.502Z zigbee-herdsman:deconz:driver query aps data indication
2021-10-10T20:29:00.507Z zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 27
2021-10-10T20:29:00.512Z zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 27 srcAddr: 0xcdec destAddr: 0x0 profile id: 0x104 cluster id: 0xef00 lqi: 255
2021-10-10T20:29:00.513Z zigbee-herdsman:deconz:frameParser response payload: 8,5,11,36,0
2021-10-10T20:29:00.514Z zigbee-herdsman:deconz:adapter resolve data request with transSeq Nr.: 5
2021-10-10T20:29:00.538Z zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":5,"manufacturerCode":null,"commandIdentifier":11},"Payload":{"cmdId":36,"statusCode":0},"Command":{"ID":11,"name":"defaultRsp","parameters":[{"name":"cmdId","type":32},{"name":"statusCode","type":32}]}},"address":52716,"endpoint":1,"linkquality":255,"groupID":null,"wasBroadcast":false,"destinationEndpoint":1}'
2021-10-10T20:29:00.544Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:29:00.545Z zigbee-herdsman:deconz:adapter response received
2021-10-10T20:29:05.381Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 28
2021-10-10T20:29:15.382Z zigbee-herdsman:deconz:driver Timeout for request - CMD: 0x7 seqNr: 28
2021-10-10T20:29:15.387Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 29
2021-10-10T20:29:15.396Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-10-10T20:29:15.396Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:29:25.380Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 30
2021-10-10T20:29:35.382Z zigbee-herdsman:deconz:driver Timeout for request - CMD: 0x7 seqNr: 30
2021-10-10T20:29:35.382Z zigbee-herdsman:deconz:driver too many timeouts - restart serial connecion
2021-10-10T20:29:35.383Z zigbee-herdsman:deconz:driver Opening with /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2428263-if00
2021-10-10T20:29:35.397Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 31
2021-10-10T20:29:35.398Z zigbee-herdsman:deconz:driver Serialport opened
2021-10-10T20:29:35.402Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-10-10T20:29:35.402Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:29:45.381Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 32
2021-10-10T20:29:45.385Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-10-10T20:29:45.385Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:29:55.384Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 33
2021-10-10T20:30:05.388Z zigbee-herdsman:deconz:driver Timeout for request - CMD: 0x7 seqNr: 33
2021-10-10T20:30:05.394Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 34
2021-10-10T20:30:05.397Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-10-10T20:30:05.397Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-10-10T20:30:15.384Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 35
W chwili obecnej mam podłączonego koordynatora - jednak sterowanie np głowicami możliwe jest tylko bezpośrednio z addona Zigbee2mqtt, przy sterowaniu z dashboard - w logach otrzymuje:
(node:329) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 316)
Mam Synology DS1515+ i dokładnie takie same problemy z tym samym sprzętem, oraz wersjami HA i firmware Conbee 2. Czy udało się może rozwiązać ten problem? Widzę że ludzie mają problemy także na zagranicznych forach z działaniem Conbee przez VMM na Synology…
@twinsen a zobacz na kanale BeardedTinker na YT. On dużo robi z HA na Synology. Nie pamiętam czy używa Conbee. Musiałbyś sprawdzić w jego filmach.
