Cześć
Na wstępie przeszedłem przez wiele wpisów dotyczących “system is not healthy” ale żadne rozwiązanie u innych nie działa u mnie.
Obecnie nie mam możliwości zainstalowania żadnej aktualizacji (czy to HA czy np. node red) ponieważ krzyczy jak na wstępie.
1. Moja instalacja
- wkleiłem zrzuty ekranów
HA jest na QNAP → VirtualizatioStation → DEBIAN
LOG ZE STRZAŁU DO AKTUALIZACJI NODE RED
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:169
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 11:34:07 (3 occurrences)
Last logged: 11:34:25
[139982180657056] Error updating Node-RED: 'AddonManager.update' blocked from execution, system is not healthy
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 167, in async_install
await async_update_addon(self.hass, slug=self._addon_slug, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'AddonManager.update' blocked from execution, system is not healthy
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1738, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 931, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 169, in async_install
raise HomeAssistantError(f"Error updating {self.title}: {err}") from err
homeassistant.exceptions.HomeAssistantError: Error updating Node-RED: 'AddonManager.update' blocked from execution, system is not healthy
Nie mam już pomysłu i wiedzy jak się za to zabrać stąd prośba o pomoc.
