jamiro
(Edgar Sousa)
December 3, 2021, 1:40pm
1
Hello All,
I am looking for some help on making work a Tuya HY367 valve.
Latest update of Zigbee2mqtt (1 December) made it possible to connect and communicate (using the TS0601 details).
Current situation is on Valve only show screen with “1P” info. Homeassistant connected, but does not make any other action.
Does someone uses one and was able to configure it? I cannot find instructions neither in Polish nor English about this.
thank you for the help
artpc
(artur)
December 3, 2021, 3:28pm
2
jamiro
(Edgar Sousa)
December 3, 2021, 4:00pm
3
Thank you. I have also the one coming with HY367, but they are a bit different and not understanding how to move from current probblem
After I connect it to zigbee, it shows this as image below. Cant move from there.
artpc
(artur)
December 3, 2021, 4:19pm
4
Did you try to remove the battery and check it again?
@jamiro
It looks like your HY367 has some kind of internal program set up, so reset it to factory settings, remove HY367 from Zigbee and setup it again.
jamiro
(Edgar Sousa)
December 3, 2021, 4:28pm
5
Many times
Also to disconnect from home assistant z2m and connect again.
Maybe full reset of valve would better approach (I tried to few times to reconnect also from valve)
