arkop
(Arkop)
26 Listopad 2023 18:49
1
Witam , Otwieram temat EDBUSA V5 w połączeniu z urządzeniami z tematu.
… wiem jest już coś podobnego tylko niestety nie działa w tej konfiguracji sprzętu.
Chyba że ktoś to ma i działa, bo mnie niestety nie znajduje sterownika i dane z pieca tez okrojone.
Link do forum na którym również szukam pomocy.
opened 06:36PM - 26 Nov 23 UTC
needs analysis
### Description
Installation in various ways does not work with loading the cor… rect data from the furnace and the controller. Below screenshots:
Screen from web edbusd:
Add-on used for Home Assist
Configuring the add-on in HA:
scanconfig: true
loglevel_all: notice
mqtttopic: ebusd
mqttint: /etc/ebusd/mqtt-hassio.cfg
mqttjson: true
http: true
network_device: enh:192.168.1.204:9999
latency: 10
configpath: /config/ebusd-configuration/ebusd-2.1.x/en
Access level: "*"
File ripped from github to config HA location:
I've looked through a million sites and tutorials, tried on Docker Synology, etc. and lime. Please help.
Below what I get after 10 min !!!
I am missing data from the 720 and, for example, gas consumption or kwh, system pressure, etc.
### Actual behavior
Dane z MGTT:
### Expected behavior
Dane z MGTT HA oraz edbusd:
### ebusd version
23.2
### ebusd arguments
> ebusd --foreground --httpport=8889 --mqtthost=core-mosquitto --mqttport=1883 --mqttuser=addons --mqttpass=PhohSeipaip0oahie0yo0airaquee8eoqu2uo8iegu1eiV0chie4upoh3paiNg8e --scanconfig --mqttjson --configpath=/config/ebusd-configuration/ebusd-2.1.x/en --latency=10 --mqttint=/etc/ebusd/mqtt-hassio.cfg --mqtttopic=ebusd --device=enh:192.168.1.204:9999 --log=all:notice
### Operating system
other
### CPU architecture
x64
### Dockerized
same as ebusd version
### Hardware interface
adapter 5 via WiFi
### Related integration
MQTT Home Assistant via mqtt-hassio.cfg
### Logs
2023-11-26 19:31:13.309 [main notice] ebusd 23.2.p20230716 started with auto scan on device: 192.168.1.204:9999, enhanced
2023-11-26 19:31:13.449 [bus notice] device status: resetting
2023-11-26 19:31:13.449 [bus notice] bus started with own address 31/36
2023-11-26 19:31:13.453 [bus notice] signal acquired
2023-11-26 19:31:13.560 [mqtt notice] connection established
2023-11-26 19:31:13.721 [bus notice] device status: reset, supports info
2023-11-26 19:31:13.789 [bus notice] device status: extra info: firmware 1.1[3a0f].1[3a0f], jumpers 0x0f
2023-11-26 19:31:13.836 [bus notice] new master 03, master count 2
2023-11-26 19:31:13.894 [bus notice] new master 10, master count 3
2023-11-26 19:31:13.894 [bus notice] scan 15: ;Vaillant;CTLV2;0514;1104
2023-11-26 19:31:13.894 [update notice] store 15 ident: done
2023-11-26 19:31:13.894 [update notice] received scan-read scan.15 QQ=03: Vaillant;CTLV2;0514;1104
2023-11-26 19:31:18.615 [update notice] received unknown MS cmd: 1008b5110101 / 09393990ffff470000ff
2023-11-26 19:31:18.891 [update notice] received unknown MS cmd: 1008b51009000047ffffff000000 / 0101
2023-11-26 19:31:23.701 [bus notice] scan 08: ;Vaillant;BAI00;1003;7603
2023-11-26 19:31:23.701 [update notice] store 08 ident: done
2023-11-26 19:31:23.701 [update notice] sent scan-read scan.08 QQ=31: Vaillant;BAI00;1003;7603
2023-11-26 19:31:23.707 [main notice] read common config file vaillant/general.csv
2023-11-26 19:31:23.708 [main notice] read common config file vaillant/scan.csv
2023-11-26 19:31:23.709 [main notice] read common config file vaillant/broadcast.csv
2023-11-26 19:31:23.710 [main notice] read scan config file vaillant/08.bai.csv for ID "bai00", SW1003, HW7603
2023-11-26 19:31:23.961 [update notice] sent scan-read scan.08 id QQ=31:
2023-11-26 19:31:24.241 [update notice] sent scan-read scan.08 id QQ=31:
2023-11-26 19:31:24.521 [update notice] sent scan-read scan.08 id QQ=31:
2023-11-26 19:31:24.790 [update notice] sent scan-read scan.08 id QQ=31: 21;23;15;0010024647;0001;006864;N0
2023-11-26 19:31:24.807 [main notice] found messages: 225 (3 conditional on 28 conditions, 0 poll, 10 update)
2023-11-26 19:31:25.060 [update notice] sent scan-read scan.08 id QQ=31: 21;23;15;0010024647;0001;006864;N0
2023-11-26 19:31:25.331 [update notice] sent scan-read scan.08 id QQ=31: 21;23;15;0010024647;0001;006864;N0
2023-11-26 19:31:25.601 [update notice] sent scan-read scan.08 id QQ=31: 21;23;15;0010024647;0001;006864;N0
2023-11-26 19:31:25.870 [update notice] sent scan-read scan.08 id QQ=31: 21;23;15;0010024647;0001;006864;N0
2023-11-26 19:31:25.870 [bus notice] scan 08: ;21;23;15;0010024647;0001;006864;N0
2023-11-26 19:31:28.141 [update notice] sent unknown MS cmd: 3115b5090124 / 09003231323231353030
2023-11-26 19:31:28.400 [update notice] sent scan-read scan.15 id QQ=31:
2023-11-26 19:31:28.660 [update notice] sent scan-read scan.15 id QQ=31:
2023-11-26 19:31:28.777 [update notice] received read bai Status01 QQ=10: 28.5;28.5;-0.438;-;35.5;off
2023-11-26 19:31:28.970 [update notice] sent scan-read scan.15 id QQ=31: 21;22;15;0020260916;0953;018537;N0
2023-11-26 19:31:28.970 [bus notice] scan 15: ;21;22;15;0020260916;0953;018537;N0
2023-11-26 19:31:28.972 [main error] unable to load scan config 15: no file from vaillant with prefix 15 matches ID "ctlv2", SW0514, HW1104
2023-11-26 19:31:28.972 [main error] scan config 15: ERR: element not found
2023-11-26 19:31:29.032 [bus notice] max. symbols per second: 104
2023-11-26 19:31:29.210 [update notice] received update-write bai SetMode QQ=10: auto;35.5;-;-;0;0;0;0;0;0
2023-11-26 19:31:30.170 [update notice] sent poll-read bai CounterStartattempts1 QQ=31: 0
2023-11-26 19:31:35.282 [update notice] sent poll-read bai CounterStartattempts2 QQ=31: 0
2023-11-26 19:31:38.605 [update notice] received read bai Status01 QQ=10: 28.5;28.5;-0.438;-;35.5;off
2023-11-26 19:31:38.881 [update notice] received update-write bai SetMode QQ=10: auto;35.5;-;-;0;0;0;0;0;0
2023-11-26 19:31:39.140 [update notice] received poll-read bai Status02 QQ=10: auto;60;75.0;70;70.0
