Zainstalowałem sobie przez HASC - Ytube Music Player GitHub - KoljaWindeler/ytube_music_player: YouTube music player for homeassistant
Lecz nie mogę poradzić sobie z dodaniem głośników bluetooth
Bluetooth zainstalowany i znalezione głośniki w pliku “known_devices.yaml”
Wpisy w nim:
samsung_soundbar_j_series:
mac: BT_FC:F1:36:C7:57:D7
icon:
picture:
track: true
stream_bt:
mac: BT_43:12:32:CB:D5:6F
icon:
picture:
track: true
W configuration.yaml
media_player:
- platform: ytube_music_player
speakers:- STREAM BT
- samsung_soundbar_j_series
Podczas odtwarzania mam taki błąd:
Log:
Logger: homeassistant.components.websocket_api.http.connection
Source: core.py:1399
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 21:10:24 (2 occurrences)
Last logged: 21:10:28
[281472986074032] not a valid value for dictionary value @ data[‘entity_id’]
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 135, in handle_call_service await hass.services.async_call( File “/usr/src/homeassistant/homeassistant/core.py”, line 1445, in async_call task.result() File “/usr/src/homeassistant/homeassistant/core.py”, line 1480, in _execute_service await handler.job.target(service_call) File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 204, in handle_service await self.hass.helpers.service.entity_service_call( File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 593, in entity_service_call future.result() # pop exception if have File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 664, in async_request_call await coro File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 630, in _handle_entity_call await result File “/usr/src/homeassistant/homeassistant/components/media_player/init.py”, line 630, in async_play_media await self.hass.async_add_executor_job( File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run result = self.fn(*self.args, **self.kwargs) File “/config/custom_components/ytube_music_player/media_player.py”, line 1062, in play_media self._play() File “/config/custom_components/ytube_music_player/media_player.py”, line 792, in _play self._get_track() File “/config/custom_components/ytube_music_player/media_player.py”, line 884, in _get_track self.hass.services.call(DOMAIN_MP, SERVICE_PLAY_MEDIA, data) File “/usr/src/homeassistant/homeassistant/core.py”, line 1357, in call return asyncio.run_coroutine_threadsafe( File “/usr/local/lib/python3.8/concurrent/futures/_base.py”, line 439, in result return self.__get_result() File “/usr/local/lib/python3.8/concurrent/futures/_base.py”, line 388, in __get_result raise self._exception File “/usr/src/homeassistant/homeassistant/core.py”, line 1399, in async_call processed_data = handler.schema(service_data) File “/usr/local/lib/python3.8/site-packages/voluptuous/validators.py”, line 218, in call return self._exec((Schema(val) for val in self.validators), v) File “/usr/local/lib/python3.8/site-packages/voluptuous/validators.py”, line 340, in _exec raise e if self.msg is None else AllInvalid(self.msg, path=path) File “/usr/local/lib/python3.8/site-packages/voluptuous/validators.py”, line 336, in _exec v = func(v) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled([], data) File “/usr/local/lib/python3.8/site-packages/voluptuous/validators.py”, line 215, in _run return self._exec(self._compiled, value, path) File “/usr/local/lib/python3.8/site-packages/voluptuous/validators.py”, line 340, in _exec raise e if self.msg is None else AllInvalid(self.msg, path=path) File “/usr/local/lib/python3.8/site-packages/voluptuous/validators.py”, line 338, in _exec v = func(path, v) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 817, in validate_callable return schema(data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled([], data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict return base_validate(path, iteritems(data), out) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data[‘entity_id’]
A tak wygląda wtyczka:
