Konfig:
homeassistant:
enabled: true
advanced:
network_key:
- 242
[redacted]
- 132
pan_id: 14700
ext_pan_id:
- 46
[redacted]
- 230
log_level: info
mqtt:
user: addons
password: [redacted]
serial:
port: /dev/ttyUSB0
adapter: ezsp
frontend:
enabled: true
port: 8099
device_options: {}
devices:
'0xa4c13840b06f528b':
friendly_name: stryczek testowy
'0xb40ecfd0c4820000':
friendly_name: Jaskinia
'0xf082c0fffe0a30d5':
friendly_name: łazienka
'0x70b3d52b6005cc4e':
friendly_name: Gniazdo - antena
version: 4
I log ze startu, nie minuta, bo to szybko startuje, a potem leci non stop to co wcześniej wklejałem, więc omijam:
[18:54:51] INFO: e[32mPreparing to start...e[0m
[18:54:51] INFO: e[32mSocat not enablede[0m
[18:54:51] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2025-02-20 18:54:51] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-02-20 18:54:51] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-20 18:54:51] e[32minfoe[39m: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-20 18:54:51] e[32minfoe[39m: zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Nabu Casa","serialNumber":"6012266d1e97ed11bcb7be98a7669f5d","pnpId":"usb-Nabu_Casa_SkyConnect_v1.0_6012266d1e97ed11bcb7be98a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"} => ezsp: 4
[2025-02-20 18:54:52] e[33mwarninge[39m: zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: zigbee-herdsman started (resumed)
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Coordinator firmware version: '{"meta":{"maintrel":"1 ","majorrel":"7","minorrel":"1","product":9,"revision":"7.1.1.0 build 273"},"type":"EZSP v9"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: stryczek testowy (0xa4c13840b06f528b): WHD02 - Tuya Wall switch module (Router)
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Jaskinia (0xb40ecfd0c4820000): SWITCH-ZR03-1 - eWeLink Zigbee smart switch (Router)
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: łazienka (0xf082c0fffe0a30d5): ZM-105B-M - Moes 2 gang smart dimmer module (Router)
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Gniazdo - antena (0x70b3d52b6005cc4e): LSPA9 - Elivco Smart plug (with power monitoring) (Router)
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Currently 4 devices are joined.
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Connected to MQTT server
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Started frontend on port 8099
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/stryczek testowy', payload '{"countdown":0,"linkquality":120,"power_on_behavior":"previous","state":"ON","switch_type":"toggle"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Jaskinia', payload '{"linkquality":196,"power_on_behavior":"previous","state":"OFF"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka', payload '{"brightness_l1":4,"brightness_l2":4,"countdown_l1":0,"countdown_l2":0,"light_type_l1":"incandescent","light_type_l2":"incandescent","linkquality":116,"max_brightness_l1":255,"max_brightness_l2":255,"min_brightness_l1":4,"min_brightness_l2":4,"power_on_behavior":"on","state_l1":"ON","state_l2":"ON"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/l1', payload '{"brightness":4,"countdown":0,"light_type":"incandescent","max_brightness":255,"min_brightness":4,"state":"ON"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Gniazdo - antena', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.02,"energy":0.01,"indicator_mode":"off/on","linkquality":144,"power":2,"power_outage_memory":"restore","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":226}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/l2', payload '{"brightness":4,"countdown":0,"light_type":"incandescent","max_brightness":255,"min_brightness":4,"state":"ON"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/type_l1', payload '{"light":"incandescent"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m: Zigbee2MQTT started!
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/type_l2', payload '{"light":"incandescent"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka', payload '{"brightness_l1":4,"brightness_l2":4,"countdown_l1":0,"countdown_l2":0,"light_type_l1":"incandescent","light_type_l2":"incandescent","linkquality":128,"max_brightness_l1":255,"max_brightness_l2":255,"min_brightness_l1":4,"min_brightness_l2":4,"power_on_behavior":"on","state_l1":"ON","state_l2":"ON"}'
[2025-02-20 18:54:56] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka', payload '{"brightness_l1":4,"brightness_l2":4,"countdown_l1":0,"countdown_l2":0,"light_type_l1":"incandescent","light_type_l2":"incandescent","linkquality":132,"max_brightness_l1":255,"max_brightness_l2":255,"min_brightness_l1":4,"min_brightness_l2":4,"power_on_behavior":"on","state_l1":"ON","state_l2":"ON"}'
[2025-02-20 18:54:57] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka', payload '{"brightness_l1":4,"brightness_l2":4,"countdown_l1":0,"countdown_l2":0,"light_type_l1":"incandescent","light_type_l2":"incandescent","linkquality":132,"max_brightness_l1":255,"max_brightness_l2":255,"min_brightness_l1":4,"min_brightness_l2":4,"power_on_behavior":"on","state_l1":"ON","state_l2":"ON"}'
[2025-02-20 18:54:57] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/l1', payload '{"brightness":4,"countdown":0,"light_type":"incandescent","max_brightness":255,"min_brightness":4,"state":"ON"}'
[2025-02-20 18:54:57] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/l2', payload '{"brightness":4,"countdown":0,"light_type":"incandescent","max_brightness":255,"min_brightness":4,"state":"ON"}'
[2025-02-20 18:54:57] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/type_l1', payload '{"light":"incandescent"}'
[2025-02-20 18:54:57] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka/type_l2', payload '{"light":"incandescent"}'
[2025-02-20 18:54:57] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka', payload '{"brightness_l1":4,"brightness_l2":4,"countdown_l1":0,"countdown_l2":0,"light_type_l1":"incandescent","light_type_l2":"incandescent","linkquality":124,"max_brightness_l1":255,"max_brightness_l2":255,"min_brightness_l1":4,"min_brightness_l2":4,"power_on_behavior":"on","state_l1":"ON","state_l2":"ON"}'
[2025-02-20 18:54:57] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka', payload '{"brightness_l1":4,"brightness_l2":4,"countdown_l1":0,"countdown_l2":0,"light_type_l1":"incandescent","light_type_l2":"incandescent","linkquality":128,"max_brightness_l1":255,"max_brightness_l2":255,"min_brightness_l1":4,"min_brightness_l2":4,"power_on_behavior":"on","state_l1":"ON","state_l2":"ON"}'
[2025-02-20 18:54:58] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/łazienka', payload '{"brightness_l1":4,"brightness_l2":4,"countdown_l1":0,"countdown_l2":
Resztę rzeczy zrobię jak szwagier powróci. Tymczasem żarówki nadal się żarzą, nie wiem jak je opanować, nigdy nie schodzą do zera, a jak ręcznie wymuszę to potem i tak zmieniają:
