[{"id":"fc96e9d3a8e1281f","type":"switch","z":"a1a507d0.5581c8","name":"histereza","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"0.3","vt":"str"},{"t":"lt","v":"0.1","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":400,"y":600,"wires":[["9f9a679f0846e3d9"],["e8e48220c2e4c916"]]},{"id":"7aeb14636dc6f535","type":"change","z":"a1a507d0.5581c8","name":"On","rules":[{"t":"set","p":"power","pt":"flow","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":560,"wires":[["3d977e53015de7c3"]]},{"id":"6c91d8ae575fdd99","type":"change","z":"a1a507d0.5581c8","name":"Off","rules":[{"t":"set","p":"power","pt":"flow","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":660,"wires":[["763efde571f8d43d"]]},{"id":"9f9a679f0846e3d9","type":"switch","z":"a1a507d0.5581c8","name":"off?","property":"power","propertyType":"flow","rules":[{"t":"eq","v":"off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":560,"wires":[["7aeb14636dc6f535"],[]]},{"id":"8cd285406ba0ca55","type":"inject","z":"a1a507d0.5581c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0.4","payloadType":"str","x":190,"y":540,"wires":[["fc96e9d3a8e1281f"]]},{"id":"3d977e53015de7c3","type":"debug","z":"a1a507d0.5581c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":850,"y":560,"wires":[]},{"id":"763efde571f8d43d","type":"debug","z":"a1a507d0.5581c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":850,"y":660,"wires":[]},{"id":"d60227da13d1e969","type":"inject","z":"a1a507d0.5581c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payloadType":"date","x":530,"y":700,"wires":[["6c91d8ae575fdd99"]]},{"id":"796274fda226353d","type":"inject","z":"a1a507d0.5581c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"str","x":190,"y":680,"wires":[["fc96e9d3a8e1281f"]]},{"id":"e8e48220c2e4c916","type":"switch","z":"a1a507d0.5581c8","name":"on?","property":"power","propertyType":"flow","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":550,"y":640,"wires":[["6c91d8ae575fdd99"],[]]}]
Mi robi
Zmienio w “histereza” typ payload z number (09) na string(az), tak to jest jak się coś robi ze screen`ów.
Poklikaj sobie to sprawdzisz czy wykonuje się tylko raz.
