Zarówka IKEA LED2003G10
Mam problem z żarówką Tradfri LED2003G10.
Parowanie po Z2M przechodzi bez problemu, żarówka pojawia się na liście, ale niestety nie można nią sterować.
log z Z2M:
Zigbee2MQTT:error 2022-10-27 14:16:46: Publish 'set' 'state' to '0x040d84fffe9b198c' failed: 'Error: Command 0x040d84fffe9b198c/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)'
Zigbee2MQTT:error 2022-10-27 14:16:47: Publish 'set' 'brightness' to '0x040d84fffe9b198c' failed: 'Error: Command 0x040d84fffe9b198c/1 genLevelCtrl.moveToLevelWithOnOff({"level":117,"transtime":0}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)'
Zigbee2MQTT:error 2022-10-27 14:16:48: Publish 'set' 'brightness' to '0x040d84fffe9b198c' failed: 'Error: Command 0x040d84fffe9b198c/1 genLevelCtrl.moveToLevelWithOnOff({"level":0,"transtime":0}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)'
Zigbee2MQTT:error 2022-10-27 14:16:50: Publish 'set' 'color_temp' to '0x040d84fffe9b198c' failed: 'Error: Command 0x040d84fffe9b198c/1 lightingColorCtrl.moveToColorTemp({"colortemp":250,"transtime":0}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)'
Mam też inną z Ikea LED1836G9 i tu wszystko jest OK.
Czy żarówka jest wadliwa czy brak umiejętności z mojej strony
  1. Sprawdź czy masz wyłączone beta wersje w ustawieniach OTA dla osprzętu, jeśli tak to wyłącz, bo niektóre firmware bywają problematyczne.
  2. Sprawdź czy nie jesteś w trakcie aktualizacji firmware.
  3. Jeśli nie, to zresetuj i sparuj ponownie.
  4. Jeśli tak, to poczekaj aż się zaktualizuje i wróć do 2.
  5. Sprawdź czy jest dostępna aktualizacja firmware, jeśli tak, to zaktualizuj i wróć do 1.
@szopen, dzięki za podpowiedź,
Brakowało jednego punktu :slight_smile:
5. Wkręć żarówkę do innej lampy, nie wiem dlaczego ale dopiero to pomogło
Ta “trefna” lampa ma metalowy klosz?
Nie, klosz z materiału, jedynie ta na której się udało jest 1m od dongla, a ta pierwotna 3m
Nie jestem na bieżąco, ale żarówki Ikei chyba od pewnego czasu wymagają parowania w trybie Touchlink (przynajmniej z mostkiem Hue teraz się tak parują, a w takim trybie paruję sprzęt trzymając go dosłownie centymetry od koordynatora).
