### Problem description
I just received Tuya powerplugs 16A and 20A. The 20A …is detected with a quirk but not the 16A, so metering not showing the right values and some functions are missing.
- the 16A plug is detected as a "class": "zigpy.device.Device"
- the 20A plug is detected as a "class": "ts011f_plug.Plug_v2"
### Solution description
Trying to make my own local quirk but i don't get it to match the right way. Started with Plug_v2 from ts_011f_plug.py
UPDATE... Got the local quirk working, updated the one in this issue. Is it possible to add this to the default file?
### Screenshots/Video
<details><summary>Screenshots/Video</summary>
[Paste/upload your media here]
</details>
### Device signature
<details><summary>Device signature</summary>
```json
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.FullFunctionDevice|MainsPowered|RxOnWhenIdle|AllocateAddress: 142>, manufacturer_code=4660, maximum_buffer_size=108, maximum_incoming_transfer_size=0, server_mask=11264, maximum_outgoing_transfer_size=0, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0100",
"input_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x000a",
"0x0702",
"0x0b04",
"0x1000",
"0xe000",
"0xe001"
"output_clusters": []
"manufacturer": "_TZ3000_okaz9tjs",
"model": "TS011F",
</details>
### Diagnostic information
<details><summary>Diagnostic information</summary>
```json
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.1.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Amsterdam",
"os_name": "Linux",
"os_version": "6.1.63-haos-raspi",
"supervisor": "2023.12.0",
"host_os": "Home Assistant OS 11.3",
"docker_version": "24.0.7",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"hacs": {
"version": "1.33.0",
"requirements": [
"aiogithubapi>=22.10.1"
"localtuya": {
"version": "5.2.1",
"requirements": []
"zha_toolkit": {
"version": "v1.1.8",
"requirements": [
"pytz"
"afvalbeheer": {
"version": "5.2.12",
"requirements": [
"rsa",
"pycryptodome"
"lghorizon": {
"version": "0.5.3",
"requirements": [
"lghorizon>=0.6.3"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly",
"@TheJulianJES"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp",
"universal_silabs_flasher"
"requirements": [
"bellows==0.37.6",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.109",
"zigpy-deconz==0.22.4",
"zigpy==0.60.4",
"zigpy-xbee==0.20.1",
"zigpy-zigate==0.12.0",
"zigpy-znp==0.12.1",
"universal-silabs-flasher==0.0.15",
"pyserial-asyncio-fast==0.11"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "0403",
"pid": "6015",
"known_devices": [
"Conbee III"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_uzg-01._tcp.local.",
"name": "uzg-01*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 4800,
"model": "TS011F",
"name": "_TZ3000_okaz9tjs TS011F",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"quirk_id": null,
"manufacturer_code": 4660,
"power_source": "Mains",
"lqi": 92,
"rssi": -77,
"last_seen": "2024-01-09T20:06:51",
"available": true,
"device_type": "Router",
"signature": {
"endpoints": {
"1": {
"input_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x000a",
"0x0702",
"0x0b04",
"0x1000",
"0xe000",
"0xe001"
"model": "TS011F"
"active_coordinator": false,
"entities": [
"entity_id": "button.tz3000_okaz9tjs_ts011f_identify_3",
"entity_id": "light.tz3000_okaz9tjs_ts011f_light",
"entity_id": "select.tz3000_okaz9tjs_ts011f_start_up_behavior",
"entity_id": "sensor.tz3000_okaz9tjs_ts011f_current_3",
"entity_id": "sensor.tz3000_okaz9tjs_ts011f_voltage_3",
"entity_id": "sensor.tz3000_okaz9tjs_ts011f_power_3",
"entity_id": "sensor.tz3000_okaz9tjs_ts011f_summation_delivered_3",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "ON_OFF_LIGHT"
"user_given_name": null,
"device_reg_id": "2375fee79cfabbcb2d9786fbe0281b41",
"area_id": null,
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_LIGHT",
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZ3000_okaz9tjs"
"0x0005": {
"attribute_name": "model",
"value": "TS011F"
"unsupported_attributes": {}
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x4002": {
"attribute_name": "off_wait_time",
"value": 0
"0x0000": {
"attribute_name": "on_off",
"value": 0
"0x4001": {
"attribute_name": "on_time",
"value": 0
"0x4003": {
"attribute_name": "start_up_on_off",
"value": 255
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x1000": {
"endpoint_attribute": "lightlink",
"attributes": {},
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0xe001": {
"endpoint_attribute": null,
"attributes": {},
"0xe000": {
"attributes": {},
"0x0702": {
"endpoint_attribute": "smartenergy_metering",
"attributes": {
"0x0000": {
"attribute_name": "current_summ_delivered",
"value": 0
"0x0302": {
"attribute_name": "divisor",
"value": 1280
"0x0306": {
"attribute_name": "metering_device_type",
"value": 0
"0x0301": {
"attribute_name": "multiplier",
"value": 1280
"0x0200": {
"attribute_name": "status",
"value": 0
"0x0303": {
"attribute_name": "summation_formatting",
"value": 0
"0x0300": {
"attribute_name": "unit_of_measure",
"value": 0
"0x0400": {
"attribute_name": "instantaneous_demand"
"0x0100": {
"attribute_name": "current_tier1_summ_delivered"
"0x0102": {
"attribute_name": "current_tier2_summ_delivered"
"0x0104": {
"attribute_name": "current_tier3_summ_delivered"
"0x0304": {
"attribute_name": "demand_formatting"
"0x0106": {
"attribute_name": "current_tier4_summ_delivered"
"0x0108": {
"attribute_name": "current_tier5_summ_delivered"
"0x010a": {
"attribute_name": "current_tier6_summ_delivered"
"0x0b04": {
"endpoint_attribute": "electrical_measurement",
"attributes": {
"0x0603": {
"attribute_name": "ac_current_divisor",
"value": 1
"0x0602": {
"attribute_name": "ac_current_multiplier",
"value": 1
"0x0605": {
"attribute_name": "ac_power_divisor",
"value": 1
"0x0604": {
"attribute_name": "ac_power_multiplier",
"value": 1
"0x0601": {
"attribute_name": "ac_voltage_divisor",
"value": 1
"0x0600": {
"attribute_name": "ac_voltage_multiplier",
"value": 1
"0x050b": {
"attribute_name": "active_power",
"value": 0
"0x0508": {
"attribute_name": "rms_current",
"value": 0
"0x0505": {
"attribute_name": "rms_voltage",
"value": 239
"0x0300": {
"attribute_name": "ac_frequency"
"0x0401": {
"attribute_name": "ac_frequency_divisor"
"0x0302": {
"attribute_name": "ac_frequency_max"
"0x050a": {
"attribute_name": "rms_current_max"
"0x0400": {
"attribute_name": "ac_frequency_multiplier"
"0x0000": {
"attribute_name": "measurement_type"
"0x0507": {
"attribute_name": "rms_voltage_max"
"0x0403": {
"attribute_name": "power_divisor"
"0x0402": {
"attribute_name": "power_multiplier"
"0x050d": {
"attribute_name": "active_power_max"
"0x050f": {
"attribute_name": "apparent_power"
"0x0510": {
"attribute_name": "power_factor"
"out_clusters": {}
</details>
### Logs
<details><summary>Logs</summary>
```python
[Paste the logs here]
</details>
### Custom quirk
<details><summary>Custom quirk</summary>
```python
class Plug_16A(EnchantedDevice):
"""Another TS011F Tuya plug. First one using this definition is _TZ3000_okaz9tjs."""
quirk_id = TUYA_PLUG_ONOFF
signature = {
MODEL: "TS011F",
ENDPOINTS: {
# "profile_id": 260,
# "device_type": "0x0100",
# "in_clusters": ["0x0000","0x0003","0x0004","0x0005","0x0006","0x000a","0x0702","0x0b04","0x1000","0xe000","0xe001"],
# "out_clusters": []
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.ON_OFF_LIGHT,
INPUT_CLUSTERS: [
Basic.cluster_id,
Identify.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
OnOff.cluster_id,
Time.cluster_id,
Metering.cluster_id,
ElectricalMeasurement.cluster_id,
LightLink.cluster_id,
TuyaZBE000Cluster.cluster_id,
TuyaZBExternalSwitchTypeCluster.cluster_id,
OUTPUT_CLUSTERS: [],
replacement = {
ENDPOINTS: {
1: {
DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaZBOnOffAttributeCluster,
Time.cluster_id,
TuyaZBMeteringClusterWithUnit,
TuyaZBElectricalMeasurement,
TuyaZBE000Cluster,
TuyaZBExternalSwitchTypeCluster,
</details>
### Additional information
When joining the device keep getting the mismatch: Fail because device_type mismatch on at least one endpoint
