chciałem wskoczyć level wyżej i przenieść automatyzacje do Node-red. Tu zaczęły się schody. Zbudowałem flow, ktore obiera wszystko z mqtt, rozdziela wg urzadzenia, a nastepnie na poszczegolne stany. Zauważyłem, ze dość często wiadomości przychodzą podwójnie. Zajrzałem w logi zigbee2mqtt i faktycznie tak się dzieje.
Cytat
debug 2023-10-27 08:48:07: Received MQTT message on ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch/set’ with data ‘{“state_l1”:“ON”}’
debug 2023-10-27 08:48:07: Publishing ‘set’ ‘state’ to ‘hallway_outdoor_lights_triple_switch’
info 2023-10-27 08:48:07: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch’, payload ‘{“backlight_mode”:“OFF”,“last_seen”:“2023-10-27T08:48:07+02:00”,“linkquality”:142,“power_on_behavior”:“off”,“power_on_behavior_l1”:“off”,“state_l1”:“OFF”,“state_l2”:“OFF”,“state_l3”:“OFF”,“switch_type”:“toggle”}’
info 2023-10-27 08:48:07: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch’, payload ‘{“backlight_mode”:“OFF”,“last_seen”:“2023-10-27T08:48:07+02:00”,“linkquality”:142,“power_on_behavior”:“off”,“power_on_behavior_l1”:“off”,“state_l1”:“ON”,“state_l2”:“OFF”,“state_l3”:“OFF”,“switch_type”:“toggle”}’
debug 2023-10-27 08:48:07: Received Zigbee message from ‘hallway_outdoor_lights_triple_switch’, type ‘attributeReport’, cluster ‘genOnOff’, data ‘{“onOff”:1}’ from endpoint 1 with groupID 0
info 2023-10-27 08:48:07: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch’, payload ‘{“action”:“on_l1”,“backlight_mode”:“OFF”,“last_seen”:“2023-10-27T08:48:07+02:00”,“linkquality”:142,“power_on_behavior”:“off”,“power_on_behavior_l1”:“off”,“state_l1”:“ON”,“state_l2”:“OFF”,“state_l3”:“OFF”,“switch_type”:“toggle”}’
info 2023-10-27 08:48:07: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch’, payload ‘{“action”:“”,“backlight_mode”:“OFF”,“last_seen”:“2023-10-27T08:48:07+02:00”,“linkquality”:142,“power_on_behavior”:“off”,“power_on_behavior_l1”:“off”,“state_l1”:“ON”,“state_l2”:“OFF”,“state_l3”:“OFF”,“switch_type”:“toggle”}’
info 2023-10-27 08:48:07: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch/action’, payload ‘on_l1’
debug 2023-10-27 08:48:10: Received Zigbee message from ‘hallway_outdoor_lights_triple_switch’, type ‘attributeReport’, cluster ‘genOnOff’, data ‘{“onOff”:1}’ from endpoint 1 with groupID 0
info 2023-10-27 08:48:10: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch’, payload ‘{“action”:“on_l1”,“backlight_mode”:“OFF”,“last_seen”:“2023-10-27T08:48:10+02:00”,“linkquality”:142,“power_on_behavior”:“off”,“power_on_behavior_l1”:“off”,“state_l1”:“ON”,“state_l2”:“OFF”,“state_l3”:“OFF”,“switch_type”:“toggle”}’
info 2023-10-27 08:48:10: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch’, payload ‘{“action”:“”,“backlight_mode”:“OFF”,“last_seen”:“2023-10-27T08:48:10+02:00”,“linkquality”:142,“power_on_behavior”:“off”,“power_on_behavior_l1”:“off”,“state_l1”:“ON”,“state_l2”:“OFF”,“state_l3”:“OFF”,“switch_type”:“toggle”}’
info 2023-10-27 08:48:10: MQTT publish: topic ‘zigbee2mqtt/hallway_outdoor_lights_triple_switch/action’, payload ‘on_l1’
Widziałem githubie projektu, że problem się ciągnie od dłuższego czasu… Czy ktoś tu się spotkał z takim problemem? Czy jest inna alternatywa dla zigbee2mqtt?
