Mam w domu kilka przycisków zintegrowanych na zigbee2mqtt.
Ostatnio zauważyłem że przyciski z których dłużej nie korzystałem przechodzą jak by w tryb uśpienia. jak klikam pierwszy raz nie włącza się automatyzacja dopiero za drugim razem zaskakuje.
Dziś w logach zauważyłem coś takiego
Pierwsze kliknięcie:
Debug 2023-10-25 20:59:04Received Zigbee message from 'Bedroom_button_tow', type 'attributeReport', cluster 'genPowerCfg', data '{"batteryPercentageRemaining":200}' from endpoint 1 with groupID 0
Info 2023-10-25 20:59:04MQTT publish: topic 'zigbee2mqtt/Bedroom_button_tow', payload '{"action":null,"battery":100,"linkquality":117,"voltage":3000}'
Debug 2023-10-25 20:59:05Received Zigbee message from 'Bedroom_button_tow', type 'raw', cluster 'genOnOff', data '{"data":[1,6,253,0],"type":"Buffer"}' from endpoint 1 with groupID 0
Debug 2023-10-25 20:59:06Received Zigbee message from 'Bedroom_button_tow', type 'raw', cluster 'genOnOff', data '{"data":[1,6,253,0],"type":"Buffer"}' from endpoint 1 with groupID 0
Drugie kliknięcie po chwili
Debug 2023-10-25 20:59:30Received Zigbee message from 'Bedroom_button_tow', type 'attributeReport', cluster 'genPowerCfg', data '{"batteryPercentageRemaining":200}' from endpoint 1 with groupID 0
Info 2023-10-25 20:59:30MQTT publish: topic 'zigbee2mqtt/Bedroom_button_tow', payload '{"action":null,"battery":100,"linkquality":111,"voltage":3000}'
Debug 2023-10-25 20:59:30Received Zigbee message from 'Bedroom_button_tow', type 'raw', cluster 'genOnOff', data '{"data":[1,8,253,0],"type":"Buffer"}' from endpoint 1 with groupID 0
Info 2023-10-25 20:59:30MQTT publish: topic 'zigbee2mqtt/Bedroom_button_tow', payload '{"action":"1_single","battery":100,"linkquality":114,"voltage":3000}'
Info 2023-10-25 20:59:30MQTT publish: topic 'zigbee2mqtt/Bedroom_button_tow', payload '{"action":"","battery":100,"linkquality":114,"voltage":3000}'
Info 2023-10-25 20:59:30MQTT publish: topic 'zigbee2mqtt/Bedroom_button_tow/action', payload '1_single'
Czy macie może pomysł co może to powodować ?
Dzięki z góry za pomoc.
Pozdrawiam
Marcin
