Wysypało mi się Zigbee2mqtt, logi z rozruchu”
[12:29:27] INFO: Preparing to start...
[12:29:27] INFO: Socat not enabled
[12:29:28] INFO: Starting Zigbee2MQTT...
[2026-06-29 12:29:30] debug: z2m: Removing old log directory '/config/zigbee2mqtt/log/2026-06-29.09-43-10'
[2026-06-29 12:29:30] info: z2m: Logging to console, file (filename: log.log)
[2026-06-29 12:29:30] debug: z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2026-06-29 12:29:30] info: z2m: Starting Zigbee2MQTT version 2.12.0 (commit #unknown)
[2026-06-29 12:29:30] info: z2m: Starting zigbee-herdsman (10.4.0)
[2026-06-29 12:29:30] debug: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":6754,\"extendedPanID\":[221,221,221,221,221,221,221,221],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"path\":\"tcp://192.168.1.201:6638\",\"adapter\":\"zstack\"},\"adapter\":{\"disableLED\":false,\"transmitPower\":20}}"'
[2026-06-29 12:29:31] debug: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","extendedPanID":[221,221,221,221,221,221,221,221],"panID":6754,"channelList":[11]},"serialPort":{"path":"tcp://192.168.1.201:6638","adapter":"zstack"},"adapter":{"disableLED":false,"transmitPower":20},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
[2026-06-29 12:29:31] info: zh:zstack:znp: Opening TCP socket with 192.168.1.201:6638
[2026-06-29 12:29:31] info: zh:zstack:znp: Socket connected
[2026-06-29 12:29:31] info: zh:zstack:znp: Socket ready
[2026-06-29 12:29:31] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2026-06-29 12:29:31] debug: zh:zstack:unpi:writer: --> buffer [239]
[2026-06-29 12:29:32] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2026-06-29 12:29:32] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2026-06-29 12:29:32] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2026-06-29 12:29:38] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2026-06-29 12:29:38] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2026-06-29 12:29:44] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2026-06-29 12:29:44] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2026-06-29 12:29:50] error: z2m: Error while starting zigbee-herdsman
[2026-06-29 12:29:50] error: z2m: Failed to start zigbee-herdsman
[2026-06-29 12:29:50] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-06-29 12:29:50] error: z2m: Exiting...
[2026-06-29 12:29:50] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@10.4.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:95:27)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@10.4.0/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:117:29)
at start (/app/index.js:156:5)
Używam koordynatora Adapter SLZB-06 Zigbee CC2652P.
