Zigbee2MQTT z HUE
A przy MQTT mam jeszcze takie wpisy
1729199660: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199661: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199662: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199664: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199665: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199668: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199672: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199679: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199692: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199719: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
1729199771: mosquitto version 2.0.20 starting
1729199771: Config loaded from /mosquitto/config/mosquitto.conf.
1729199771: Starting in local only mode. Connections will only be possible from clients running on this machine.
1729199771: Create a configuration file which defines a listener to allow remote access.
1729199771: For more details see Authentication methods | Eclipse Mosquitto
1729199771: Opening ipv4 listen socket on port 1883.
1729199771: Opening ipv6 listen socket on port 1883.
1729199771: mosquitto version 2.0.20 running
1729200191: mosquitto version 2.0.20 terminating
Czy ja dobrze rozumiem, że startowałeś Z2M mając zamknięty broker?
Skoro nie radzisz sobie z tak skomplikowaną instalacją tego wszystkiego, to nie rozumiem czemu nie zamierzasz korzystać z instalacji HAOS…
to jakies stare logi w tej chwili nie ma tam nic
2024-10-17T21:14:20.642843928Z 1729199660: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:21.639605023Z 1729199661: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:22.784685447Z 1729199662: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:24.011730832Z 1729199664: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:25.618425077Z 1729199665: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:28.049825420Z 1729199668: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:32.095159963Z 1729199672: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:39.312243645Z 1729199679: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:14:52.798700576Z 1729199692: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:15:19.223736501Z 1729199719: Error: Unable to open config file /mosquitto/config/mosquitto.conf.
2024-10-17T21:16:11.225966445Z 1729199771: mosquitto version 2.0.20 starting
2024-10-17T21:16:11.226121563Z 1729199771: Config loaded from /mosquitto/config/mosquitto.conf.
2024-10-17T21:16:11.226140138Z 1729199771: Starting in local only mode. Connections will only be possible from clients running on this machine.
2024-10-17T21:16:11.226157591Z 1729199771: Create a configuration file which defines a listener to allow remote access.
2024-10-17T21:16:11.226173980Z 1729199771: For more details see https://mosquitto.org/documentation/authentication-methods/
2024-10-17T21:16:11.226190213Z 1729199771: Opening ipv4 listen socket on port 1883.
2024-10-17T21:16:11.226206387Z 1729199771: Opening ipv6 listen socket on port 1883.
2024-10-17T21:16:11.226222349Z 1729199771: mosquitto version 2.0.20 running
2024-10-17T21:23:11.004040829Z 1729200191: mosquitto version 2.0.20 terminating
Nie rozumiem czemu tak sie stało skoro nic nie zmianiałem.
Wyjecie koordynatora spowodowało taki problem ?
Tego nie wiemy, ja jak kiedyś chciałem wymienić oponę w rowerze na biegu to w palcach mam ciągle error.
Wklej tu swoją konfiguracje koordynatora z Dodatki → Z2M.
@artpc - zanim zaczniesz pomagać koledze…
@dawide73 - ja odpuszczam odpisywanie na twoje posty, bo uznałem, że dopóki nie będziesz się starał zrozumieć jak to wszystko działa i nie pozyskasz samodzielnie więcej wiedzy, to szkoda mojego czasu. Wybrałeś najwyższy z możliwych, moim zdaniem, próg wejścia do HA, Z2M itd tworząc instancję na OMV i kontenery Docker, którego nie rozumiesz w działaniu. Więc próby pomocy to jak rozmowa dwóch osób w innym języku. Dopóki nie poznasz języka technicznego i zrozumiesz pojęć, nie widzę sensu mnożenia kolejnych postów.
Takiej mieszanki to jeszcze nie widziałem. Mi zajęło to kilka lat, a kolega @dawide73 ogarnia to w 2 tygodnie.
Tu się całkowicie zgadzam, wiele dodatków, integracji jest aktualizowanych do nowych wymagań HA i bez aktualizacji przestana działać prędzej czy później.
W przedostatniej aktualizacji Z2M dodana została nowa ścieżka dla Z2M
addon_configs45df7312_zigbee2mqtt więc w którejś aktualizacji HA zostaną przeniesione tam pliki konfiguracyjne.
Aktualizacje kontenerów to ja robie raz w tygodniu.
Aktualiazcje firmware w urzadzeniu to jest ostateczność.
Już jest lepiej :slight_smile:
[2024-11-07 16:09:55] info: 	z2m: Logging to console, file (filename: log.log)
[2024-11-07 16:09:55] info: 	z2m: Starting Zigbee2MQTT version 1.41.0 (commit #cc31cea)
[2024-11-07 16:09:55] info: 	z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-07 16:09:56] info: 	zh:ember: Using default stack config.
[2024-11-07 16:09:56] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-11-07 16:09:56] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-11-07 16:09:56] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-11-07 16:09:56] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-11-07 16:09:56] info: 	zh:ember:uart:ash: Serial port opened
[2024-11-07 16:09:56] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-11-07 16:09:56] error: 	zh:ember:uart:ash: Received ERROR from adapter while connecting, with code=RESET_WATCHDOG.
[2024-11-07 16:09:58] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2024-11-07 16:09:58] info: 	zh:ember:uart:ash: ======== ASH started ========
[2024-11-07 16:09:58] info: 	zh:ember:ezsp: ======== EZSP started ========
[2024-11-07 16:09:58] info: 	zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2024-11-07 16:09:58] info: 	zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.2 [GA]","build":0,"major":7,"minor":4,"patch":2,"special":0,"type":170}
[2024-11-07 16:09:58] info: 	zh:ember: [STACK STATUS] Network up.
[2024-11-07 16:09:58] info: 	zh:ember: [INIT TC] Adapter network matches config.
[2024-11-07 16:09:58] info: 	zh:ember: [CONCENTRATOR] Started source route discovery. 1247ms until next broadcast.
[2024-11-07 16:09:58] info: 	z2m: zigbee-herdsman started (resumed)
[2024-11-07 16:09:58] info: 	z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":2,"revision":"7.4.2 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2024-11-07 16:09:58] info: 	z2m: Drzwi wejściowe (0xa4c1383c75120615): SNZB-04 - SONOFF Contact sensor (EndDevice)
[2024-11-07 16:09:58] info: 	z2m: Salon Xiaomi (0xa4c138030e3f8d02): LYWSD03MMC-z - Xiaomi Temp & RH Monitor Lite (pvxx/ZigbeeTLc) (EndDevice)
[2024-11-07 16:09:58] info: 	z2m: Currently 2 devices are joined.
[2024-11-07 16:09:58] warning: 	z2m: `permit_join` set to  `true` in configuration.yaml.
[2024-11-07 16:09:58] warning: 	z2m: Allowing new devices to join.
[2024-11-07 16:09:58] warning: 	z2m: Set `permit_join` to `false` once you joined all devices.
[2024-11-07 16:09:58] info: 	z2m: Zigbee: allowing new devices to join.
[2024-11-07 16:09:58] info: 	zh:ember: [STACK STATUS] Network opened.
[2024-11-07 16:09:59] info: 	z2m: Connecting to MQTT server at mqtt://192.168.100.67:1883
[2024-11-07 16:09:59] info: 	z2m: Connected to MQTT server
[2024-11-07 16:09:59] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2024-11-07 16:09:59] info: 	z2m: Started frontend on port 8080
[2024-11-07 16:09:59] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Drzwi wejściowe', payload '{"battery":32,"battery_low":false,"contact":true,"linkquality":80,"tamper":false,"voltage":2500}'
[2024-11-07 16:09:59] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Salon Xiaomi', payload '{"battery":75.5,"comfort_display":null,"comfort_humidity_max":60,"comfort_humidity_min":40,"comfort_temperature_max":25,"comfort_temperature_min":20,"display":"on","humidity":55.7,"humidity_calibration":0,"linkquality":132,"measurement_interval":10,"temperature":20.5,"temperature_calibration":0,"temperature_display_mode":"celsius","update":{"installed_version":19083265,"latest_version":19017729,"state":"idle"},"update_available":null}'
[2024-11-07 16:09:59] info: 	z2m: Zigbee2MQTT started!
został tylko błąd
i już nie ma tego problemu
[2024-11-07 16:43:19] info: 	z2m: Logging to console, file (filename: log.log)
[2024-11-07 16:43:19] info: 	z2m: Starting Zigbee2MQTT version 1.41.0 (commit #cc31cea)
[2024-11-07 16:43:19] info: 	z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-07 16:43:19] info: 	zh:ember: Using default stack config.
[2024-11-07 16:43:19] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-11-07 16:43:19] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-11-07 16:43:19] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-11-07 16:43:19] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-11-07 16:43:19] info: 	zh:ember:uart:ash: Serial port opened
[2024-11-07 16:43:19] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-11-07 16:43:21] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2024-11-07 16:43:21] info: 	zh:ember:uart:ash: ======== ASH started ========
[2024-11-07 16:43:21] info: 	zh:ember:ezsp: ======== EZSP started ========
[2024-11-07 16:43:21] info: 	zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2024-11-07 16:43:21] info: 	zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.2 [GA]","build":0,"major":7,"minor":4,"patch":2,"special":0,"type":170}
[2024-11-07 16:43:21] info: 	zh:ember: [STACK STATUS] Network up.
[2024-11-07 16:43:21] info: 	zh:ember: [INIT TC] Adapter network matches config.
[2024-11-07 16:43:21] info: 	zh:ember: [CONCENTRATOR] Started source route discovery. 1247ms until next broadcast.
[2024-11-07 16:43:21] info: 	z2m: zigbee-herdsman started (resumed)
[2024-11-07 16:43:21] info: 	z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":2,"revision":"7.4.2 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2024-11-07 16:43:21] info: 	z2m: Drzwi wejściowe (0xa4c1383c75120615): SNZB-04 - SONOFF Contact sensor (EndDevice)
[2024-11-07 16:43:21] info: 	z2m: Salon Xiaomi (0xa4c138030e3f8d02): LYWSD03MMC-z - Xiaomi Temp & RH Monitor Lite (pvxx/ZigbeeTLc) (EndDevice)
[2024-11-07 16:43:21] info: 	z2m: Currently 2 devices are joined.
[2024-11-07 16:43:21] warning: 	z2m: `permit_join` set to  `true` in configuration.yaml.
[2024-11-07 16:43:21] warning: 	z2m: Allowing new devices to join.
[2024-11-07 16:43:21] warning: 	z2m: Set `permit_join` to `false` once you joined all devices.
[2024-11-07 16:43:21] info: 	z2m: Zigbee: allowing new devices to join.
[2024-11-07 16:43:21] info: 	zh:ember: [STACK STATUS] Network opened.
[2024-11-07 16:43:22] info: 	z2m: Connecting to MQTT server at mqtt://192.168.100.67:1883
[2024-11-07 16:43:22] info: 	z2m: Connected to MQTT server
[2024-11-07 16:43:22] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2024-11-07 16:43:22] info: 	z2m: Started frontend on port 8080
[2024-11-07 16:43:22] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Drzwi wejściowe', payload '{"battery":32,"battery_low":false,"contact":true,"linkquality":80,"tamper":false,"voltage":2500}'
ale temat dotyczył żarówki której teraz zigbee2mqtt nie wykrywa
@dawide73
Bardzo proszę nie pisz postu pod swoim postem tylko edytuj ostatni wpis.
@dawide73 bardzo prosze o niepisanie posta pod swoim postem, jezeli chcesz cos dodać do poprzedniej swoje wypowiedzi skorzystaj proszę z edycji posta i dopisz nowe informacje.
@artpc widzę, że Tobie to juz też zaczęło przeszkadzać :slight_smile:
@dawide73
Skoro już naprawiłeś, to napisz jak, niech coś zostanie dla potomnych.
Zasadniczo Z2M do startu wymaga 3 składników
  • dostępu do koordynatora (jeśli wyjmiesz go na biegu to kontener zakończy działalność z braku sprzętu), dlatego kiedyś proponowałem ścieżkę by-id (wtedy nie zmienia się ona np. wskutek podpięcia do innego portu czy podłączaniu urządzeń w innej kolejności)
  • dostępu do brokera (jeśli broker MQTT jest niedostępny to Z2M też się zamknie lub będzie próbowało restartować)
  • dostępu do własnej konfiguracji (bo twój koordynator nie jest w stanie uruchomić się na domyślnej dla Z2M)
A wracając do żarówki
po pierwsze
Możesz ją usunąć i dodać ponownie.
(musi by zasięgu koordynatora)
po drugie
Jeśli nie jesteś w stanie sprawić by była online możesz zrobić wymuszone usunięcie ALE musisz być w stanie ją zresetować w inny sposób.
Jako posiadacz innego sprzętu Hue jesteś na wygranej pozycji, bo możesz żarówkę dodać do mostka po nadrukowanym kodzie parowania (i następnie ją usunąć - powinna się zresetować i przejść do trybu parowania), masz też pewnie piloty Hue, a nimi można zresetować żarówki Hue metodą Touchlink
Warto też sprawdzić bazę urządzeń, czy w ogóle posiadana żarówka jest w obsługiwanych (szczególnie jeśli chodzi o jakąś nowość na rynku).
PS Teraz to trochę wyszło wykopalisko, ale często piszę mając mnóstwo innych spraw na głowie i prawie gotowy post został w szkicach…
