Witam jak uruchomic ZigBee2MQTT.
[19:16:05] INFO: Preparing to start...
[19:16:05] INFO: Socat not enabled
[19:16:06] INFO: Starting Zigbee2MQTT...
[2025-05-23 19:16:08] info: z2m: Logging to console, file (filename: log.log)
[2025-05-23 19:16:08] info: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-23 19:16:08] info: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-23 19:16:08] info: zh:zstack:znp: Opening TCP socket with 192.168.5.37:6638
[2025-05-23 19:16:08] info: zh:zstack:znp: Socket connected
[2025-05-23 19:16:08] info: zh:zstack:znp: Socket ready
[2025-05-23 19:16:08] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-05-23 19:16:09] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: - PAN ID: configured=9102, adapter=11654
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: - Extended PAN ID: configured=27782ac68beba8b5, adapter=98b13a600ddb2a38
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: - Network Key: configured=7bbd7c4dd7f6503803fac690188ac515, adapter=e8d404fe2ef4491656782272eac1ac05
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: - Channel List: configured=11, adapter=11
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /config/zigbee2mqtt/coordinator_backup.json.
[2025-05-23 19:16:09] error: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
[2025-05-23 19:16:09] error: z2m: Error while starting zigbee-herdsman
[2025-05-23 19:16:09] error: z2m: Failed to start zigbee-herdsman
[2025-05-23 19:16:09] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-23 19:16:09] error: z2m: Exiting...
[2025-05-23 19:16:09] error: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at ZnpAdapterManager.determineStrategy (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:248:23)
at processTicksAndRejections (node:internal/process/task_queues:105:5)
at ZnpAdapterManager.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:62:26)
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:154:16)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:104:13)
at start (/app/index.js:149:5)
socat:
enabled: false
options: "-d -d"
log: false
mqtt:
server: mqtt://localhost:1883
user: my_user
password: my_password
serial:
port: tcp://192.168.5.37:6638
baudrate: 115200
adapter: zstack
disable_led: false
advanced:
transmit_power: 20
