Tak jak pisałem, mam ustawienia takie same jak w trzecim poście.
Parametr Tolerance mam na 1, Target mam na auto.
Nie wiem co jeszcze mam zmieniać, brak mi już pomysłów.
I teraz najlepsze: po wrzuceniu części logów termostat - uspokoił się, tzn logi są generowane ale silnik termostatu milczy lub uruchomi się raz na kilka kilkanaście minut na ćwierć sekundy
2025-02-18 13:04:38.202 WARNING (MainThread) [homeassistant.components.mqtt.entity] JSON result was not a dictionary
2025-02-18 13:04:38.203 WARNING (MainThread) [homeassistant.components.mqtt.entity] JSON result was not a dictionary
2025-02-18 13:04:54.365 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.1
2025-02-18 13:04:54.372 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:05:32.451 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.1 to 22.0
2025-02-18 13:05:32.454 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:05:38.480 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.1
2025-02-18 13:05:38.488 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:06:02.548 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.1 to 22.0
2025-02-18 13:06:02.551 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:06:20.673 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.2
2025-02-18 13:06:20.676 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.2, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:06:26.610 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.2 to 22.1
2025-02-18 13:06:26.613 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:07:04.701 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.1 to 22.0
2025-02-18 13:07:04.710 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:07:36.756 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.1
2025-02-18 13:07:36.763 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:07:46.803 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.1 to 22.0
2025-02-18 13:07:46.810 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:08:10.855 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.1
2025-02-18 13:08:10.861 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:08:52.941 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.1 to 22.0
2025-02-18 13:08:52.946 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:09:06.967 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.2
2025-02-18 13:09:06.976 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.2, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:09:35.037 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.2 to 22.0
2025-02-18 13:09:35.043 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:09:38.325 WARNING (MainThread) [homeassistant.components.mqtt.entity] JSON result was not a dictionary
2025-02-18 13:09:38.327 WARNING (MainThread) [homeassistant.components.mqtt.entity] JSON result was not a dictionary
2025-02-18 13:09:41.073 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.2
2025-02-18 13:09:41.076 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.2, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:09:49.169 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.2 to 22.0
2025-02-18 13:09:49.172 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:10:17.123 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.1
2025-02-18 13:10:17.129 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:10:37.185 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.1 to 22.0
2025-02-18 13:10:37.187 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:10:51.212 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.2
2025-02-18 13:10:51.217 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.2, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:10:57.263 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.2 to 22.0
2025-02-18 13:10:57.266 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.0, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:11:05.255 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.0 to 22.1
2025-02-18 13:11:05.261 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:11:15.277 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.1 to 22.2
2025-02-18 13:11:15.286 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.2, target_temp: 22.0, trv_temp: 26.8
2025-02-18 13:11:25.313 DEBUG (MainThread) [custom_components.better_thermostat.events.temperature] better_thermostat None: external_temperature changed from 22.2 to 22.1
2025-02-18 13:11:25.323 DEBUG (MainThread) [custom_components.better_thermostat.calibration] better_thermostat None: climate.termostat - new setpoint calibration: 26.5 | external_temp: 22.1, target_temp: 22.0, trv_temp: 26.8
