Witam
Dzisiaj postawiłem poraz pierwszy HA na dell wyse na debian. Mam problem z Node Red. Czysta instalacja nic nie wrzucone jeszcze, dodałem node reda i jest błąd błąd 502: Bad Gateway. Czy ktoś miał może coś takiego. Jeszcze zadany integracji nic nie robiłem.
credential_secret: ‘’
dark_mode: false
http_node:
username: ‘’
password: ‘’
http_static:
username: ‘’
password: ‘’
ssl: false
certfile: fullchain.pem
keyfile: privkey.pem
require_ssl: false
system_packages: []
npm_packages: []
init_commands: []
s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 7.2.11
System: Debian GNU/Linux 10 (buster) (amd64 / qemux86-64)
Home Assistant Core: 2020.12.2
Home Assistant Supervisor: 2020.12.7
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing…
[15:16:54] FATAL:
[15:16:54] FATAL: Configuration of this add-on is incomplete.
[15:16:54] FATAL:
[15:16:54] FATAL: Please be sure to set the “credential_secret” option.
[15:16:54] FATAL:
[15:16:54] FATAL: The credential secret is an encryption token, much like
[15:16:54] FATAL: a password, that is used by Node-RED for encrypting
[15:16:54] FATAL: credentials you put into Node-RED.
[15:16:54] FATAL:
[15:16:54] FATAL: Just like a password, a credential secret can be
[15:16:54] FATAL: anything you like. Just be sure to store it somewhere
[15:16:54] FATAL: safe for later, e.g., in case of a recovery.
[15:16:54] FATAL:
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
Be sure to check the log above, line by line, for hints.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Przecież wszystko jest w logach, wystarczy przeczytać, w razie problemów skorzystaj z Google Translatora, zacznij od rozwiązania tego:
Taki wpis jak poniżej:
oznacza, że skrypt node-red.sh wykonał się ale z błędem (uruchomił i zakończył się ale z błędem), kod wynikowy to 1 czyli:
Exit code 1 General errors, Miscellaneous errors, such as "divide by zero" and other impermissible operations
Jak widać pozostałe skrypty 00-banner.sh, nginx.sh, itd zakończyły się poprawnie, kod wyjścia 0 czyli:
Exit code 0 Success
Pomagam w rozwiązywaniu problemów ucząc jak je później rozwiązywać samemu ![]()
Ustawiłem hasło błąd jest dalej
Pokaż logi, wtedy bedę pewny, że ustawiłeś hasło.
Oki dzięki wielkie udało się
dziękuję za pomoc dopiero zaczynam zabawę dzisiaj sprzęt przyszedł pierwsze instalacja i wogule
Proszę bardzo
, na przyszłość pamiętaj: zanim napiszesz sprawdź logi, jak sobie nie poradzisz opisz dokładnie problem i dołącz logi, szybciej będzie Ci można pomóć.
P.S. Odpowiedziałem tylko dlatego, że dodałeś logi bo wtedy wiadomo gdzie jest problem
Tak rozumiem na początku duzo tego sprzęt,Linux HA obsługa logi
Uczymy się całe życie.
Dokładnie jeszcze raz wielkie dzięki
Dokładnie uczymy się cały czas.
U mnie ruszyło dopiero jak ustawiłem dowolne hasło w pierwszym wierszu, i zmianie ssl: (true ,na false).
Cytat
credential_secret: xxxxxx
dark_mode: true
http_node:
username: ‘’
password: ‘’
http_static:
username: ‘’
password: ‘’
ssl: false
require_ssl: true
system_packages:
npm_packages:
init_commands:
Cytat
Przesiadam się z Nettempa i dla mnie trochę nie logiczne są ustawienia w HASS
Podepnę się pod temat. Jak w temacie co bym nie zrobił mam odpowiedź: 502: Bad Gateway.
W logu raczej błędów nie widzę choć ostatnie dwie linijki mnie zastanawiają:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Node-RED
Add-on version: 10.0.0
Home Assistant Core: 2021.8.6
Home Assistant Supervisor: 2021.06.8
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] customizations.sh: executing...
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] node-red.sh: executing...
patching file nodes/ui_base.html
Hunk #1 succeeded at 1162 (offset 631 lines).
up to date, audited 1 package in 2s
found 0 vulnerabilities
[cont-init.d] node-red.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:44:17] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js "--settings" "/etc/node-red/config.js"
14 Aug 22:44:23 - [info]
Welcome to Node-RED
14 Aug 22:44:23 - [info] Node-RED version: v2.0.5
14 Aug 22:44:23 - [info] Node.js version: v14.17.4
14 Aug 22:44:23 - [info] Linux 4.19.0-17-amd64 x64 LE
14 Aug 22:44:25 - [info] Loading palette nodes
14 Aug 22:44:33 - [info] Dashboard version 2.30.0 started at /endpoint/ui
/bin/sh: /opt/node_modules/node-red-node-pi-gpio/testgpio.py: not found
14 Aug 22:44:34 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
14 Aug 22:44:34 - [info] Settings file : /etc/node-red/config.js
14 Aug 22:44:34 - [info] Context store : 'default' [module=memory]
14 Aug 22:44:34 - [info] User directory : /config/node-red/
14 Aug 22:44:34 - [warn] Projects disabled : editorTheme.projects.enabled=false
14 Aug 22:44:34 - [info] Flows file : /config/node-red/flows.json
14 Aug 22:44:35 - [info] Server now running at http://127.0.0.1:46836/
14 Aug 22:44:35 - [info] Starting flows
14 Aug 22:44:35 - [info] Started flows
[22:44:35] INFO: Starting NGinx...
14 Aug 22:44:40 - [info] [server:Home Assistant] Connecting to undefined
14 Aug 22:44:40 - [info] [server:Home Assistant] Connected to undefined
Natomiast konfiguracja:
credential_secret: ************
theme: default
http_node:
username: xyz
password: xyz
http_static:
username: xyz1
password: xyz1
ssl: false
system_packages: []
npm_packages: []
init_commands: []
require_ssl: true
Nie znam się na tym ale zastanawiam się nad poprawną konfiguracją
ssl: false
require_ssl: true
Ja mam taką konfigurację
credential_secret: xxxxxxxxxxx
theme: default
http_node:
username: ''
password: ''
http_static:
username: ''
password: ''
ssl: true
system_packages: []
npm_packages: []
init_commands: []
require_ssl: true
Ten parametr nie jest już obsługiwany.
DJS
theme: default
http_node:
username: ‘’
password: ‘’
http_static:
username: ‘’
password: ‘’
ssl: false
system_packages:
npm_packages:
init_commands:
log_level: info
Node-RED version: v2.0.5 po aktualizacji do tej wersji w mojej konfiguracji NR totalnie padł, wszystko uruchamiało się bez błędów ale dashboard totalnie martwy, brak jakichkolwiek zmian wyswietlanych w nodach. Nr uruchamiany z paska HA, natomiast uruchomienie NR z adresu 192...68:1880 ożywiało dashboard ale wciąż wysokie użycie procka na poziomie 27%. Wróciłem do poprzedniej wersji NR i wszystko działa normalnie. Wygląda mi to na problemy z komunikacją między HA a NR
Tak wygląda mój start NR
Home Assistant Core: 2021.8.7
Log level is set to INFO
[cont-init.d] done.
[services.d] done.
[13:46:20] INFO: Starting Node-RED...
> start
16 Aug 13:46:24 - [info]
Welcome to Node-RED
16 Aug 13:46:24 - [info] Node-RED version: v2.0.5
16 Aug 13:46:24 - [info] Node.js version: v14.17.4
16 Aug 13:46:24 - [info] Linux 4.19.0-17-amd64 x64 LE
16 Aug 13:46:25 - [info] Loading palette nodes
BAIL ON node-red-contrib-fcm-receive-node/fcm-receive
16 Aug 13:46:40 - [info] mDashboard version 2.19.4-beta started at /endpoint/mui
16 Aug 13:46:47 - [info] Dashboard version 2.30.0 started at /endpoint/ui
BAIL ON node-red-node-ui-table/ui_table
16 Aug 13:46:49 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
BAIL ON node-red-node-twitter/twitter
16 Aug 13:46:50 - [warn] ------------------------------------------------------
16 Aug 13:46:50 - [warn] [node-red-node-rbe/rbe] 'rbe' already registered by module node-red
16 Aug 13:46:50 - [warn] [node-red-contrib-flogger-now/flogger] 'flogger' already registered by module node-red-contrib-flogger
16 Aug 13:46:50 - [info] Settings file : /etc/node-red/config.js
16 Aug 13:46:50 - [info] Context store : 'default' [module=memory]
16 Aug 13:46:50 - [info] User directory : /config/node-red/
16 Aug 13:46:50 - [warn] Projects disabled : editorTheme.projects.enabled=false
16 Aug 13:46:50 - [info] Flows file : /config/node-red/flows.json
16 Aug 13:46:50 - [info] Server now running at http://127.0.0.1:46836/
[13:46:50] INFO: Starting NGinx...
16 Aug 13:51:56 - [info] Starting flows
fileServer listening on ip 192.168.1.69 and port 8089
Jeżeli NR masz na słabszym sprzęcie to poczekaj dłuższa chwile na załadowanie NR
Panowie pomożecie ? Nie daje sobie z tym rady. Jestem początkujacy. HA postawiony na Rpi4
[20:11:49] FATAL:
[20:11:49] FATAL: SSL has been enabled using the 'ssl' option,
[20:11:49] FATAL: this requires a SSL certificate file which is
[20:11:49] FATAL: configured using the 'certfile' option in the
[20:11:49] FATAL: add-on configuration.
[20:11:49] FATAL:
[20:11:49] FATAL: Unfortunately, the file specified in the
[20:11:49] FATAL: 'certfile' option does not exists.
[20:11:49] FATAL:
[20:11:49] FATAL: Please ensure the certificate file exists and
[20:11:49] FATAL: is placed in the '/ssl/' directory.
[20:11:49] FATAL:
[20:11:49] FATAL: In case you don't have SSL yet, consider getting
[20:11:49] FATAL: a SSL certificate or setting the 'ssl' option
[20:11:49] FATAL: to 'false' in case you are not planning on using
[20:11:49] FATAL: SSL with this add-on.
[20:11:49] FATAL:
[20:11:49] FATAL: Check the add-on manual for more information.
[20:11:49] FATAL:
[cont-init.d] nginx.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Wyłącz SSL
ssl: false
require_ssl: false
Cześć
mam od wczoraj ten sam problem ( [Node-Red add-on and 502 bad gateway), ale nie wiem gdzie się znajdują pliki te konfiguracyjne NR.
