dziś rano wstałem i z2m nie działa mi . długo było ok . urzadzenie działa , zresetowałem je i dalej cisza. wklejam logi
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:142:13)
at start (/app/index.js:161:5)
[11:09:28] INFO: Preparing to start…
[11:09:28] INFO: Socat not enabled
[11:09:29] INFO: Starting Zigbee2MQTT…
[2025-01-05 11:09:30] info: z2m: Logging to console, file (filename: log.log)
[2025-01-05 11:09:30] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-05 11:09:30] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-05 11:09:30] info: zh:zstack:znp: Opening SerialPort with {“path”:“/dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-06_a639a8da61ceed119b9f9a2ecda106c3-if00-port0”,“baudRate”:115200,“rtscts”:false,“autoOpen”:false}
[2025-01-05 11:09:30] info: zh:zstack:znp: Serialport opened
[2025-01-05 11:09:30] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-01-05 11:09:31] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-01-05 11:09:50] error: z2m: Error while starting zigbee-herdsman
[2025-01-05 11:09:50] error: z2m: Failed to start zigbee-herdsman
[2025-01-05 11:09:50] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-01-05 11:09:50] error: z2m: Exiting…
[2025-01-05 11:09:50] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[11:09:50] INFO: Preparing to start…
[11:09:50] INFO: Socat not enabled
[11:09:51] INFO: Starting Zigbee2MQTT…
[2025-01-05 11:09:52] info: z2m: Logging to console, file (filename: log.log)
[2025-01-05 11:09:52] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-05 11:09:52] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-05 11:09:52] info: zh:zstack:znp: Opening SerialPort with {“path”:“/dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-06_a639a8da61ceed119b9f9a2ecda106c3-if00-port0”,“baudRate”:115200,“rtscts”:false,“autoOpen”:false}
[2025-01-05 11:09:52] info: zh:zstack:znp: Serialport opened
[2025-01-05 11:09:52] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-01-05 11:09:53] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-01-05 11:10:12] error: z2m: Error while starting zigbee-herdsman
[2025-01-05 11:10:12] error: z2m: Failed to start zigbee-herdsman
[2025-01-05 11:10:12] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-01-05 11:10:12] error: z2m: Exiting…
[2025-01-05 11:10:12] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[11:10:12] INFO: Preparing to start…
[11:10:12] INFO: Socat not enabled
[11:10:12] INFO: Starting Zigbee2MQTT…
[2025-01-05 11:10:14] info: z2m: Logging to console, file (filename: log.log)
[2025-01-05 11:10:14] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-05 11:10:14] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-05 11:10:14] info: zh:zstack:znp: Opening SerialPort with {“path”:“/dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-06_a639a8da61ceed119b9f9a2ecda106c3-if00-port0”,“baudRate”:115200,“rtscts”:false,“autoOpen”:false}
[2025-01-05 11:10:14] info: zh:zstack:znp: Serialport opened
[2025-01-05 11:10:14] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-01-05 11:10:15] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-01-05 11:10:34] error: z2m: Error while starting zigbee-herdsman
[2025-01-05 11:10:34] error: z2m: Failed to start zigbee-herdsman
[2025-01-05 11:10:34] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-01-05 11:10:34] error: z2m: Exiting…
[2025-01-05 11:10:34] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
Samo ? raczej wcześniej zaktualizowałeś do nowej wersji … i nie czytałeś “braking changes” , poczytaj … →
https://forum.arturhome.pl/t/zbliza-sie-wydanie-zigbee2mqtt-2-0-0-bedzie-zawieralo-breaking-changes/13634
naprawiłem, zrobiłem aktualizacje kordynatora dopisałem adapter: zstack i poszło, choć moze jeszcze cos zrobiłem bo dłubałem 2 h ale działa
samo sie zaktualizowało widocznie, ale pewno masz racje
To zapobiegaj takim nieoczekiwanym aktualizacjom i świadomie to rób, wcześniej czytając jakie zmiany wnosi i co spowoduje ta zmiana …
Tak wiem , dzięki za info, od miesiąca dopiero używam i się uczę,
