Dodanie pompy ciepła Rotenso (Midea)
Witam.
Podłączyłem moje Rotenso Aquami modułem USR-DR404 WIFI TCP <=> Modbus RTU .
Do pliku configuration.yaml dodałem ten wiersz modbus: !include modbus.yaml i plik modbus.yaml a w nim:
- name: rotenso
  type: tcp
  host: 192.168.0.101
  port: 502
  delay: 5
  timeout: 2
  switches:
    - name: heatpump_on_off_toggle
      unique_id: heatpump_on_off_toggle
      slave: 1
      address: 0
      write_type: holding
      command_on: 2
      command_off: 0
      verify:
        input_type: holding
        address: 0
        state_on: 2
        state_off: 0
  sensors:
    - name: heatpump_Fan_Speed
      unique_id: heatpump_Fan_Speed
      scan_interval: 5
      address: 102
      state_class: measurement
      slave: 1
      scale: 1
      input_type: holding
      unit_of_measurement: r/min
    - name: heatpump_flow_rate
      unique_id: heatpump_flow_rate
      scan_interval: 5
      address: 138
      slave: 1
      scale: 0.01
      precision: 3
      input_type: holding
      unit_of_measurement: m3/h
    - name: heatpump_power_state
      unique_id: heatpump_power_state
      address: 0
      scan_interval: 5
      slave: 1
    - name: heatpump_temperature_C1
      unit_of_measurement: °C
      unique_id: heatpump_temperature_C1
      scan_interval: 5
      address: 2
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_temperature_TW_IN
      unique_id: heatpump_temperature_TW_IN
      scan_interval: 5
      address: 104
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_temperature_TW_OUT
      unique_id: heatpump_temperature_TW_OUT
      scan_interval: 5
      address: 105
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_condensor_temperature_T3
      unique_id: heatpump_condensor_temperature_T3
      scan_interval: 5
      address: 106
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_outdoor_temperature_T4
      unique_id: heatpump_outdoor_temperature_T4
      scan_interval: 5
      address: 107
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_exhaust_gas_temperature_Tp
      unique_id: heatpump_exhaust_gas_temperature_Tp
      scan_interval: 5
      address: 108
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_suction_temperature_Th
      unique_id: heatpump_suction_temperature_Th
      scan_interval: 5
      address: 109
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_refrigerant_liquid_side_temperature_T2
      unique_id: heatpump_refrigerant_liquid_side_temperature_T2
      scan_interval: 5
      address: 112
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_refrigerant_liquid_side_temperature_T2B
      unique_id: heatpump_refrigerant_liquid_side_temperature_T2B
      scan_interval: 5
      address: 113
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_total_water_outlet_T1
      unique_id: heatpump_total_water_outlet_T1
      scan_interval: 5
      address: 110
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_Operating_frequency_Hz
      unit_of_measurement: Hz
      unique_id: heatpump_Operating_frequency_Hz
      scan_interval: 5
      address: 100
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_Power
      unit_of_measurement: kW
      unique_id: heatpump_Power
      device_class: power
      scan_interval: 5
      address: 140
      slave: 1
      scale: 0.01
      offset: 0
      precision: 3
    - name: heatpump_PMV
      unit_of_measurement: P
      unique_id: heatpump_PMV
      device_class: energy
      scan_interval: 5
      address: 103
      state_class: total_increasing
      slave: 1
    - name: heatpump_high_pressure
      unit_of_measurement: kPa
      unique_id: heatpump_high_pressure
      scan_interval: 5
      address: 116
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_low_pressure
      unique_id: heatpump_low_pressure
      scan_interval: 360
      address: 117
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_total_climate_curve
      unique_id: heatpump_total_climate_curve
      scan_interval: 5
      address: 136
      slave: 1
      offset: 0
      scale: 1
    - name: heatpump_operating_current
      unit_of_measurement: A
      unique_id: heatpump_operating_current
      scan_interval: 5
      address: 118
      slave: 1
      scale: 1
      offset: 0
      precision: 3
    - name: heatpump_Compressor_operation_time
      unit_of_measurement: h
      unique_id: heatpump_Compressor_operation_timet
      scan_interval: 360
      address: 122
      slave: 1
      scale: 1
      offset: 0
      precision: 3
    - name: heatpump_128
      unique_id: heatpump_128
      address: 128
      scan_interval: 5
      slave: 1
      input_type: holding
    - name: heatpump_129
      unique_id: heatpump_129
      address: 129
      scan_interval: 5
      slave: 1
      input_type: holding
    - name: heatpump_electricity_consumption
      unique_id: heatpump_electricity_consumption
      address: 143
      slave: 1
      data_type: int32
      scan_interval: 60
      unit_of_measurement: kWh
      input_type: holding
    - name: heatpump_Power_output
      unique_id: heatpump_Power_output
      address: 145
      slave: 1
      data_type: int32
      scan_interval: 60
      input_type: holding
  climates:
    - name: heatpump_climate
      unique_id: heatpump_climate
      address: 110
      slave: 1
      input_type: holding
      max_temp: 50
      min_temp: 25
      precision: 1
      scale: 1
      target_temp_register: 136
      temp_step: 1
      temperature_unit: °C
      write_registers: true
      hvac_mode_register:
        address: 1
        values:
          state_auto: 1
          state_cool: 2
          state_heat: 3
    - name: Górna temp. krzywej 9
      unique_id: gorna_temp_krzywej_9
      address: 265
      data_type: int16
      input_type: holding
      max_temp: 60
      min_temp: 25
      offset: 0
      precision: 1
      scale: 1
      target_temp_register: 265
      temp_step: 1
      temperature_unit: C
      hvac_mode_register:
        address: 0001
        values:
          state_heat: 3
    - name: Dolna temp. krzywej 9
      unique_id: dolna_temp_krzywej_9
      address: 266
      data_type: int16
      input_type: holding
      max_temp: 60
      min_temp: 25
      offset: 0
      precision: 1
      scale: 1
      target_temp_register: 266
      temp_step: 1
      temperature_unit: C
      hvac_mode_register:
        address: 0001
        values:
          state_heat: 3
    - name: Dolna temp. zewn. krzywej 9
      unique_id: dolna_temp_zewn_krzywej_9
      address: 268
      data_type: int16
      input_type: holding
      max_temp: 30
      min_temp: -25
      offset: 0
      precision: 1
      scale: 1
      target_temp_register: 268
      temp_step: 1
      temperature_unit: C
      hvac_mode_register:
        address: 0001
        values:
          state_heat: 3
    - name: Górna temp. zewn. krzywej 9
      unique_id: gorna_temp_zewn_krzywej_9
      address: 267
      data_type: int16
      input_type: holding
      max_temp: 30
      min_temp: -25
      offset: 0
      precision: 1
      scale: 1
      target_temp_register: 267
      temp_step: 1
      temperature_unit: C
      hvac_mode_register:
        address: 0001
        values:
          state_heat: 3
Problem polega na tym że się nie znam i nie wiem jak odczytywać i zapisywać pojedyncze bity .NP: informacja o defroście jest na adresie 129 BIT15 ?
I termostat nie działa - na krzywej pokazuje dobrze jak wyłączę krzywą to jest 255 stopni i nie zmienia temperatury
