Mam problem w takiej postaci że do esp8266 podłączyłem konwerter rs485-ttl oparty o MAX485 z automatyczną zmianą kierunku i do licznika, problem pojawia się w momencie gdy próbuję odczytać dane z licznika to pojawia mi się błąd:
[D][modbus_controller:039]: Modbus command to device=1 register=0x202A no response received - removed from send queue
i nie mam żadnych odczytów z licznika, szukałem na forach i innym działało połączenie wykonałem tak jak na obrazku poniżej:
kod na ESP:
friendly_name: rs485
esp8266:
board: esp01_1m
networks:
- ssid: "xxx"
password: "xxx"
platform: esphome
level: DEBUG
baud_rate: 0
output:
- platform: gpio
pin: 16 # GPIO16
inverted: false # HIGH = TX, LOW = RX
uart:
tx_pin: 1
rx_pin: 3
rx_buffer_size: 512
baud_rate: 9600
parity: NONE
data_bits: 8
stop_bits: 1
modbus:
send_wait_time: 1000ms
uart_id: uart_to_modbus
modbus_controller:
- id: dtsu666_modbus_controler
address: 0x001
modbus_id: modbus_component_hub
update_interval: 30s
text_sensor:
name: "ESP-DTSU Uptime (human readable)"
icon: "mdi:clock-start"
update_interval: 5s
# Energia
- platform: modbus_controller
modbus_controller_id: dtsu666_modbus_controler
name: "Energia pobrana z sieci kwh"
address: 0x101E
unit_of_measurement: "kWh"
device_class: "energy"
register_type: read
value_type: FP32
accuracy_decimals: 2
skip_updates: 12
filters:
- multiply: 1
name: "Energia oddana do sieci kwh"
address: 0x1028
register_type: read
value_type: FP32
skip_updates: 12
filters:
- multiply: 1
# Napięcia
address: 0x200A
unit_of_measurement: "V"
register_type: read
value_type: FP32
accuracy_decimals: 1
filters:
- multiply: 0.1
address: 0x2008
register_type: read
value_type: FP32
filters:
- multiply: 0.1
address: 0x2006
register_type: read
value_type: FP32
filters:
- multiply: 0.1
# Prądy
address: 0x2010
unit_of_measurement: "A"
register_type: read
value_type: FP32
filters:
- multiply: 0.001
address: 0x200E
register_type: read
value_type: FP32
filters:
- multiply: 0.001
address: 0x200C
register_type: read
value_type: FP32
filters:
- multiply: 0.001
# moc chwilowa
name: "Moc chwilowa całkowita"
address: 0x2012
unit_of_measurement: "W"
register_type: read
value_type: FP32
accuracy_decimals: 0
filters:
- multiply: 0.1
name: "Moc chwilowa L3"
address: 0x2018
register_type: read
value_type: FP32
filters:
- multiply: 0.1
name: "Moc chwilowa L2"
address: 0x2016
register_type: read
value_type: FP32
filters:
- multiply: 0.1
name: "Moc chwilowa L1"
address: 0x2014
register_type: read
value_type: FP32
filters:
- multiply: 0.1
# power factor
address: 0x202A
unit_of_measurement: "Pf"
register_type: read
value_type: FP32
filters:
- multiply: 0.001
name: "Power Factor L1"
address: 0x202c
register_type: read
value_type: FP32
filters:
- multiply: 0.001
name: "Power Factor L2"
address: 0x202e
register_type: read
value_type: FP32
filters:
- multiply: 0.001
name: "Power Factor L3"
address: 0x2030
register_type: read
value_type: FP32
filters:
- multiply: 0.001
# wifi signal
- platform: wifi_signal
name: "WiFi Signal DTSU-Logger"
update_interval: 60s
icon: "mdi:wifi"
- platform: uptime
filters:
- lambda: return x / 60.0;
unit_of_measurement: minutes
- platform: uptime
update_interval: 5s
internal: true
on_raw_value:
then:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
unit_of_measurement: "%"
name: "ESP-DTSU WiFi Signal (human readable)"
icon: "mdi:wifi"
lambda: return (-0.0134 * (id(dtsu_wifi_signal).state * id(dtsu_wifi_signal).state ) ) + (-0.2228 * id(dtsu_wifi_signal).state) + 100.2;
# Basic switch to allow you to restart the device remotely
switch:
- platform: restart
binary_sensor:
- platform: status
Ma ktoś może jakieś pomysły dla czego to nie działa?
