Licznik AMIPlus w Tauron i problemy z aktywacją HAN (2024)
I think these PV installations that can feed power to the grid should sport the same protections against tampering as meters do (i.e. they should be sealed). So, no user access to those parameters that can affect the operation of the grid.
Cześć, mam u siebie licznik NES 73331. Aktywowałem w nim port HAN, jednak ramki przychodzą w sposób bliżej mi nieokreślony.
Tak wygląda lista pakietów od 12 marca:
> `12.03.2026:`
> `[19:28:06.392][RSSI: -56dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[20:53:43.302][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `13.03.2026:`
> `[22:07:22.717][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:07:52.717][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `14.03.2026:`
> `Brak pakietów`
> `15.03.2026:`
> `[04:21:26.825][RSSI: -56dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `16.03.2026:`
> `[12:10:14.840][RSSI: -57dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `17.03.2026:`
> `Brak pakietów`
> `18.03.2026:`
> `[22:27:15.178][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:27:45.176][RSSI: -49dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:58:02.145][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[23:09:26.133][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `19.03.2026:`
> `[00:26:02.052][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[01:07:50.057][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[01:09:20.054][RSSI: -49dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[01:09:50.060][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:50:33.837][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:14:12.685][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:18:10.681][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:20:40.679][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:21:40.678][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:22:10.678][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:30:33.716][RSSI: -49dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:32:58.667][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:33:28.668][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:33:58.673][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:35:27.719][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:35:57.711][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:37:53.661][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:38:23.663][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:55:18.691][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:57:13.641][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:59:38.686][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[07:01:07.636][RSSI: -48dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[12:19:37.301][RSSI: -47dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[16:45:18.025][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[20:56:33.761][RSSI: -52dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[21:42:53.713][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[21:43:23.719][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[21:56:46.746][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[21:59:16.745][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:00:16.743][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:00:46.742][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:01:16.742][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:01:46.743][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:02:46.740][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:06:40.737][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:11:00.731][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:36:14.705][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `20.03.2026:`
> `[00:22:24.548][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[00:23:53.593][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[00:44:15.523][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[00:44:45.523][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[00:45:15.530][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[12:16:47.792][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[12:17:17.791][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `21.03.2026:`
> `[02:09:14.967][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[09:33:55.450][RSSI: -53dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[19:19:50.884][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `22.03.2026:`
> `[02:15:59.394][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:18:54.447][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:19:24.439][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:19:54.439][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:20:24.442][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:20:54.438][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:22:24.436][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:22:54.435][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:23:54.436][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[05:16:17.207][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[05:17:46.251][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[08:54:45.973][RSSI: -54dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[09:38:29.927][RSSI: -58dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[09:40:28.973][RSSI: -58dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[09:47:23.918][RSSI: -60dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:32:20.808][RSSI: -63dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:33:50.805][RSSI: -64dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:34:20.804][RSSI: -63dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:36:45.850][RSSI: -63dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:37:45.859][RSSI: -65dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:38:45.849][RSSI: -63dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:42:09.844][RSSI: -63dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:45:38.795][RSSI: -62dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:47:38.790][RSSI: -62dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[11:49:33.840][RSSI: -63dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[23:15:32.066][RSSI: -62dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `23.03.2026:`
> `[05:53:30.647][RSSI: -63dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[09:31:48.419][RSSI: -64dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `24.03.2026:`
> `[02:35:41.353][RSSI: -66dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:37:37.391][RSSI: -66dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:56:34.323][RSSI: -68dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:58:03.370][RSSI: -67dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:58:33.368][RSSI: -65dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[02:59:03.370][RSSI: -66dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:01:32.318][RSSI: -65dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:03:32.316][RSSI: -67dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:04:02.315][RSSI: -69dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:04:32.314][RSSI: -67dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:05:02.315][RSSI: -65dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:05:32.319][RSSI: -68dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:06:02.313][RSSI: -65dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:06:32.315][RSSI: -69dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:07:32.321][RSSI: -67dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:08:02.311][RSSI: -69dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:08:32.312][RSSI: -67dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:09:32.309][RSSI: -66dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:11:27.358][RSSI: -68dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[03:19:15.350][RSSI: -66dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[04:16:29.287][RSSI: -66dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[06:21:01.109][RSSI: -67dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:24:15.100][RSSI: -56dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `[22:25:44.147][RSSI: -55dBm, mode: T1 A, mfr:NES id:000xxxxx ver:3 type:2 ci:7A]`
> `25.03.2026:`
> `Brak pakietów`
> `26.03.2026:`
> `Brak pakietów`
Zgłosiłem to tauronowi, oni jedyne co odpisują, to że przecież jest ok, bo port HAN jest aktywny. Miernik mam za ścianą od licznika, no i też jak widać, RSSI nie jest problemem.
Czy spotkał się ktoś z czymś takim?
Fajnie że wrzuciłeś log tylko pytanie zasadnicze : czym to czytasz.
Mam radyjko LilyGo TTGO LoRa32 V2.1, na SX1276. Mam na nim esphome z tym komponentem: GitHub - Kustonium/esphome-wmbus-bridge-rawonly: Bez kombajnu WMBUS · GitHub
Przy okazji szukania przyczyny czemu nie dochodzą pakiety, chciałem jak najbardziej odchudzić przetwarzanie na ESPku.
Ok - czyli wziąłeś mój egzotyk . Czekaj…
EDIT: po wymianie zdań na PW zbieramy diagnostykę jak często licznik nadaje ramkę, radio ESP czyta wszystkie inne ramki które słyszy.
