@rafkan doinstalowanie Zigbe2MQTT Assistanta zmieniło ustawienia??
jak coś to usunę tylko czy to coś pomoże czy znowu wszystko od podstaw?
W Mosquitto broker mam takie logi:
1613380391: Saving in-memory database to /data/mosquitto.db.
1613382192: Saving in-memory database to /data/mosquitto.db.
1613383993: Saving in-memory database to /data/mosquitto.db.
1613385794: Saving in-memory database to /data/mosquitto.db.
1613387595: Saving in-memory database to /data/mosquitto.db.
1613389396: Saving in-memory database to /data/mosquitto.db.
1613391197: Saving in-memory database to /data/mosquitto.db.
1613392998: Saving in-memory database to /data/mosquitto.db.
1613394799: Saving in-memory database to /data/mosquitto.db.
1613395391: Socket error on client 2WrCxDR5zrfFCLQjFKxOIO, disconnecting.
1613395513: New connection from 172.30.32.1 on port 1883.
[INFO] found mqtt on local database
1613395514: New client connected from 172.30.32.1 as 4MaYMNWnUvBIgKUzaLeY6W (p2, c1, k60, u’mqtt’).
1613396600: Saving in-memory database to /data/mosquitto.db.
1613398401: Saving in-memory database to /data/mosquitto.db.
1613400202: Saving in-memory database to /data/mosquitto.db.
1613402003: Saving in-memory database to /data/mosquitto.db.
1613402161: Client mqttjs_af578bc1 disconnected.
1613402178: New connection from 172.30.33.3 on port 1883.
1613402178: New client connected from 172.30.33.3 as mqttjs_4518937f (p2, c1, k60, u’mqtt’).
1613403804: Saving in-memory database to /data/mosquitto.db.
1613405605: Saving in-memory database to /data/mosquitto.db.
1613407406: Saving in-memory database to /data/mosquitto.db.
1613408790: Socket error on client 4MaYMNWnUvBIgKUzaLeY6W, disconnecting.
1613408826: New connection from 172.30.32.1 on port 1883.
1613408827: New client connected from 172.30.32.1 as 1LvbPUx3b21v0EiyVWOUcP (p2, c1, k60, u’mqtt’).
1613409207: Saving in-memory database to /data/mosquitto.db.
1613411008: Saving in-memory database to /data/mosquitto.db.
1613412809: Saving in-memory database to /data/mosquitto.db.
1613414610: Saving in-memory database to /data/mosquitto.db.
1613416411: Saving in-memory database to /data/mosquitto.db.
1613418212: Saving in-memory database to /data/mosquitto.db.
1613420013: Saving in-memory database to /data/mosquitto.db.
1613421814: Saving in-memory database to /data/mosquitto.db.
1613423228: Socket error on client 1LvbPUx3b21v0EiyVWOUcP, disconnecting.
1613423287: New connection from 172.30.32.1 on port 1883.
1613423288: New client connected from 172.30.32.1 as 612Y2Ejjtkq0haF8CMTrl7 (p2, c1, k60, u’mqtt’).
1613423615: Saving in-memory database to /data/mosquitto.db.
1613425416: Saving in-memory database to /data/mosquitto.db.
1613427217: Saving in-memory database to /data/mosquitto.db.
1613429018: Saving in-memory database to /data/mosquitto.db.
1613430819: Saving in-memory database to /data/mosquitto.db.
1613432620: Saving in-memory database to /data/mosquitto.db.
1613434421: Saving in-memory database to /data/mosquitto.db.
1613436222: Saving in-memory database to /data/mosquitto.db.
1613438023: Saving in-memory database to /data/mosquitto.db.
1613439824: Saving in-memory database to /data/mosquitto.db.
1613441625: Saving in-memory database to /data/mosquitto.db.
1613443426: Saving in-memory database to /data/mosquitto.db.
1613445227: Saving in-memory database to /data/mosquitto.db.
1613447028: Saving in-memory database to /data/mosquitto.db.
1613448829: Saving in-memory database to /data/mosquitto.db.
1613450630: Saving in-memory database to /data/mosquitto.db.
1613452431: Saving in-memory database to /data/mosquitto.db.
1613454232: Saving in-memory database to /data/mosquitto.db.
1613456033: Saving in-memory database to /data/mosquitto.db.
1613457834: Saving in-memory database to /data/mosquitto.db.
1613459635: Saving in-memory database to /data/mosquitto.db.
1613461436: Saving in-memory database to /data/mosquitto.db.
1613463237: Saving in-memory database to /data/mosquitto.db.
1613465038: Saving in-memory database to /data/mosquitto.db.
1613466839: Saving in-memory database to /data/mosquitto.db.
1613468640: Saving in-memory database to /data/mosquitto.db.
1613470441: Saving in-memory database to /data/mosquitto.db.
1613472242: Saving in-memory database to /data/mosquitto.db.
1613474043: Saving in-memory database to /data/mosquitto.db.
1613475844: Saving in-memory database to /data/mosquitto.db.
1613477645: Saving in-memory database to /data/mosquitto.db.
1613479446: Saving in-memory database to /data/mosquitto.db.
1613481247: Saving in-memory database to /data/mosquitto.db.
1613483048: Saving in-memory database to /data/mosquitto.db.
1613484849: Saving in-memory database to /data/mosquitto.db.
1613486650: Saving in-memory database to /data/mosquitto.db.
1613488451: Saving in-memory database to /data/mosquitto.db.
1613490252: Saving in-memory database to /data/mosquitto.db.
1613492053: Saving in-memory database to /data/mosquitto.db.
1613493854: Saving in-memory database to /data/mosquitto.db.
1613495655: Saving in-memory database to /data/mosquitto.db.
1613497456: Saving in-memory database to /data/mosquitto.db.
1613499257: Saving in-memory database to /data/mosquitto.db.
1613501058: Saving in-memory database to /data/mosquitto.db.
1613502859: Saving in-memory database to /data/mosquitto.db.
1613504660: Saving in-memory database to /data/mosquitto.db.
1613506461: Saving in-memory database to /data/mosquitto.db.
1613506734: Socket error on client 612Y2Ejjtkq0haF8CMTrl7, disconnecting.
1613506814: New connection from 172.30.32.1 on port 1883.
1613506815: New client connected from 172.30.32.1 as 5cRS7JyEtLTZIbPk45p7Tb (p2, c1, k60, u’mqtt’).
1613508262: Saving in-memory database to /data/mosquitto.db.
1613509975: New connection from 172.30.32.1 on port 1883.
[INFO] found addons on local database
1613509976: New client connected from 172.30.32.1 as mosq-F5U70fa9FX61aTP5lX (p2, c1, k60, u’addons’).
1613510063: Saving in-memory database to /data/mosquitto.db.
1613510558: Socket error on client 5cRS7JyEtLTZIbPk45p7Tb, disconnecting.
1613510573: New connection from 172.30.32.1 on port 1883.
1613510574: New client connected from 172.30.32.1 as 2qsGseILrpfhZxX4T0AxCd (p2, c1, k60, u’mqtt’).
Jeśli ustawienie brokera byłoby bez zmian to tak powinna wyglądać zakładka Mosquitto brokera:
@rafkan musze się nie zgodzić bo po naszej instalacji MQTT u nie mnie cały czas jest taki sam.
Ok, skoro tak twierdzisz to tak jest.
@rafkan już wiem co mogło się stać. W między czasie zmieniłem system na RPi4 z 32 bitowego na 64 więc może to miało wpływ?
Zainstalowałem HA na nowej karcie i zamieniłem karty i na nowej odpaliłem snapshnota
@rafkan pytanie jak myślisz czy to może być to? i co w takim przypadku z tym zrobić?
Już Ci napisałem a nawet wkleiłem screna aby ułatwić szukanie błędu jak tego nie widzisz to nie dam rady pomóc. W temacie który przytoczylem w tym wątku krok po kroku opisalem co masz zrobić.
@rafkan ok zrobię wszystko od nowa i dam Ci znać.
Wprowadz ponownie poprawne hasło dla użytkownika mqtt w menu HA: Konfiguracja → Użytkownicy i zrób restart Mosquitto broker.
Ponownie wykonaj konfigurację MQTT (menu HA: Konfiguracja → Integracje → MQTT), wprowadz jeszcze raz nazwę użytkownika i hasło.
@macek nie podziałało
Zainstalowałem wszystko od nowa bez zigbee2MQTT i teraz jak chce wprowadzić w stan parowania po wciśnięciu permit joit wyskakuje mi takie cos:
Wrazie co wysyłam logi z Zigbee2MQTT:
W konfiguracji Zigbee2MQTT nie masz wpisanych poświadczeń do brokera MQTT dlatego wlacza się tryb auto discovery z domyślnym userem ‘addons’.
Po pierwsze tryb parowania uruchamia się ja na screnie poniżej:
Po drugie masz napisane co jest źle:
Jednak zabawy z HA po nocy maja swoje minusy. Wdarła się mała literówka w haśle.
Raczej potrzebny pośpiech w nocy
, najważniejsze, że działa.
@macek to się jeszcze przekonamy jak wrócę do domu i sparuję żarówkę czy wszystko będzie działać
Sparowałem żarówkę ale z logów wynika że albo nie jest to urządzenie obsługiwane. Tylko że ta żarówka jest na liście:
a mam takie logi:
Zigbee2MQTT:warn 2021-02-17 14:21:00: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:21:00: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:21:03: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:21:03: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:21:06: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:21:06: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:21:09: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:21:09: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:21:12: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:21:12: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:23:45: Device ‘0xec1bbdfffe70e661’ left the network
Zigbee2MQTT:warn 2021-02-17 14:23:46: Device ‘0xec1bbdfffe70e661’ left the network
Zigbee2MQTT:warn 2021-02-17 14:24:19: Device ‘0xec1bbdfffe70e661’ with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’ is NOT supported, please follow How to support new devices | zigbee2mqtt.io
Zigbee2MQTT:warn 2021-02-17 14:24:53: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:24:53: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:24:56: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:24:56: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:24:59: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:24:59: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:25:02: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:25:02: Please see: How to support new devices | zigbee2mqtt.io.
Zigbee2MQTT:warn 2021-02-17 14:25:05: Received message from unsupported device with Zigbee model ‘TRADFRI bulb E27 CWS 806lm’ and manufacturer name ‘IKEA of Sweden’
Zigbee2MQTT:warn 2021-02-17 14:25:05: Please see: How to support new devices | zigbee2mqtt.io.
