a w logach:
[20:28:48] INFO: Preparing to start...
[20:28:48] INFO: Socat not enabled
[20:28:49] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-04-28 20:28:54: Logging to console and directory: '/config/zigbee2mqtt/log/2024-04-28.20-28-54' filename: log.txt
Zigbee2MQTT:info 2024-04-28 20:28:54: Starting Zigbee2MQTT version 1.36.1 (commit #unknown)
Zigbee2MQTT:info 2024-04-28 20:28:54: Starting zigbee-herdsman (0.40.3)
Zigbee2MQTT:info 2024-04-28 20:29:33: zigbee-herdsman started (restored)
Zigbee2MQTT:info 2024-04-28 20:29:33: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: Currently 0 devices are joined:
Zigbee2MQTT:info 2024-04-28 20:29:33: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2024-04-28 20:29:33: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2024-04-28 20:29:33: Connected to MQTT server
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2024-04-28 20:29:33: Started frontend on port 8099
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x7560059adb8211de","panID":23818},"permit_join":false,"version":"1.36.1"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b002a2eb530/connection_state/config', payload '{"device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x00124b002a2eb530_connection_state_zigbee2mqtt","value_template":"{{ value }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b002a2eb530/restart_required/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"problem","enabled_by_default":false,"entity_category":"diagnostic","name":"Restart required","object_id":"zigbee2mqtt_bridge_restart_required","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2eb530_restart_required_zigbee2mqtt","value_template":"{{ value_json.restart_required }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/button/1221051039810110150109113116116_0x00124b002a2eb530/restart/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/restart","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"restart","name":"Restart","object_id":"zigbee2mqtt_bridge_restart","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_press":"","unique_id":"bridge_0x00124b002a2eb530_restart_zigbee2mqtt"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/select/1221051039810110150109113116116_0x00124b002a2eb530/log_level/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","command_template":"{\"options\": {\"advanced\": {\"log_level\": \"{{ value }}\" } } }","command_topic":"zigbee2mqtt/bridge/request/options","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"entity_category":"config","name":"Log level","object_id":"zigbee2mqtt_bridge_log_level","options":["info","warn","error","debug"],"origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2eb530_log_level_zigbee2mqtt","value_template":"{{ value_json.log_level | lower }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2eb530/version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"entity_category":"diagnostic","icon":"mdi:zigbee","name":"Version","object_id":"zigbee2mqtt_bridge_version","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2eb530_version_zigbee2mqtt","value_template":"{{ value_json.version }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2eb530/coordinator_version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:chip","name":"Coordinator version","object_id":"zigbee2mqtt_bridge_coordinator_version","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2eb530_coordinator_version_zigbee2mqtt","value_template":"{{ value_json.coordinator.meta.revision }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2eb530/network_map/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"enabled_by_default":false,"entity_category":"diagnostic","json_attributes_template":"{{ value_json.data.value | tojson }}","json_attributes_topic":"zigbee2mqtt/bridge/response/networkmap","name":"Network map","object_id":"zigbee2mqtt_bridge_network_map","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/response/networkmap","unique_id":"bridge_0x00124b002a2eb530_network_map_zigbee2mqtt","value_template":"{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002a2eb530/permit_join_timeout/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"duration","entity_category":"diagnostic","name":"Permit join timeout","object_id":"zigbee2mqtt_bridge_permit_join_timeout","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2eb530_permit_join_timeout_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ iif(value_json.permit_join_timeout is defined, value_json.permit_join_timeout, None) }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: MQTT publish: topic 'homeassistant/switch/1221051039810110150109113116116_0x00124b002a2eb530/permit_join/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/permit_join","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b002a2eb530"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"icon":"mdi:human-greeting-proximity","name":"Permit join","object_id":"zigbee2mqtt_bridge_permit_join","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"false","payload_on":"true","state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002a2eb530_permit_join_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}'
Zigbee2MQTT:info 2024-04-28 20:29:33: Zigbee2MQTT started!
konfiguracja:
socat:
enabled: false
options: "-d -d"
log: false
mqtt: {}
serial:
port: /dev/ttyUSB1
zigbee_herdsman_debug: true
nie wiem co dalej, wygląda jakby wystartował i przestał działać, dalsze logi się już nie pojawiają po odświerzeniu i restartach.
