Nie mam pojęcia, na razie nic nie mam (tylko dowód że się da).
A więc. Zlutowałem Wemos D1 mini z płytka c1101 od @_Szczepan .
Wgrałem yaml na esp:
friendly_name: wmbus
esp8266:
board: d1_mini
# Enable logging
# Enable Home Assistant API
key: "xxx"
password: "xxx"
ssid: !secret wifi_ssid
ssid: "Wmbus Fallback Hotspot"
password: "xxx"
captive_portal:
time:
- platform: sntp
external_components:
components: [ wmbus ]
wmbus:
mosi_pin: D7
miso_pin: D6
clk_pin: D5
cs_pin: D8
gdo0_pin: D1
gdo2_pin: D2
led_pin: D0
led_blink_time: "1s"
clients:
- name: "wmbusmeters"
ip_address: "10.0.0.1"
port: 7227
- platform: wmbus
meter_id: 0x1782177
type: apator162
lqi:
rssi:
total_water_m3:
name: "My cold water"
logi mam takie:
INFO ESPHome 2024.3.1
INFO Reading configuration /config/esphome/wmbus.yaml...
INFO Starting log output from 192.168.0.196 using esphome API
INFO Successfully connected to wmbus @ 192.168.0.196 in 0.012s
INFO Successful handshake with wmbus @ 192.168.0.196 in 2.732s
[12:45:39][I][app:102]: ESPHome version 2024.3.1 compiled on Mar 29 2024, 12:37:56
[12:45:39][C][wifi:580]: WiFi:
[12:45:39][C][wifi:408]: Local MAC: 08:3A:8D:D0:2F:2D
[12:45:39][C][wifi:413]: SSID: 'TP-LINK_A9C28D'[redacted]
[12:45:39][C][wifi:416]: IP Address: 192.168.0.196
[12:45:39][C][wifi:419]: BSSID: 5C:A6:E6:25:D5:E4[redacted]
[12:45:39][C][wifi:421]: Hostname: 'wmbus'
[12:45:39][C][wifi:423]: Signal strength: -65 dB ▂▄▆█
[12:45:39][C][wifi:427]: Channel: 6
[12:45:39][C][wifi:428]: Subnet: 255.255.255.0
[12:45:39][C][wifi:429]: Gateway: 192.168.0.1
[12:45:39][C][wifi:430]: DNS1: 192.168.0.1
[12:45:39][C][wifi:431]: DNS2: 192.168.0.1
[12:45:39][C][logger:166]: Logger:
[12:45:39][C][logger:167]: Level: DEBUG
[12:45:39][C][logger:169]: Log Baud Rate: 115200
[12:45:39][C][logger:170]: Hardware UART: UART0
[12:45:39][C][captive_portal:088]: Captive Portal:
[12:45:39][C][sntp:055]: SNTP Time:
[12:45:39][C][sntp:056]: Server 1: '0.pool.ntp.org'
[12:45:39][C][sntp:057]: Server 2: '1.pool.ntp.org'
[12:45:39][C][sntp:058]: Server 3: '2.pool.ntp.org'
[12:45:39][C][sntp:059]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[12:45:39][C][mdns:115]: mDNS:
[12:45:39][C][mdns:116]: Hostname: wmbus
[12:45:39][C][ota:096]: Over-The-Air Updates:
[12:45:39][C][ota:097]: Address: wmbus.local:8266
[12:45:39][C][ota:100]: Using Password.
[12:45:39][C][ota:103]: OTA version: 2.
[12:45:39][C][api:139]: API Server:
[12:45:39][C][api:140]: Address: wmbus.local:6053
[12:45:39][C][api:142]: Using noise encryption: YES
[12:45:39][C][wmbus:372]: wM-Bus v3.2.1:
[12:45:39][C][wmbus:374]: Clients:
[12:45:39][C][wmbus:376]: wmbusmeters: 10.0.0.1:7227 TCP [rtl-wmbus]
[12:45:39][C][wmbus:385]: LED:
[12:45:39][C][wmbus:386]: Pin: GPIO16
[12:45:39][C][wmbus:387]: Duration: 1000 ms
[12:45:39][C][wmbus:389]: CC1101 frequency: 868.950 MHz
[12:45:39][C][wmbus:390]: CC1101 SPI bus:
[12:45:39][C][wmbus:391]: MOSI Pin: GPIO13
[12:45:39][C][wmbus:392]: MISO Pin: GPIO12
[12:45:39][C][wmbus:393]: CLK Pin: GPIO14
[12:45:39][C][wmbus:394]: CS Pin: GPIO15
[12:45:39][C][wmbus:395]: GDO0 Pin: GPIO5
[12:45:39][C][wmbus:396]: GDO2 Pin: GPIO4
[12:45:39][C][wmbus:403]: Available drivers: amiplus, apator08, apator162, apatoreitn, bmeters, c5isf, compact5, dme07, elf, evo868, fhkvdataiii, flowiq2200, hydrocalm3, hydrus, iperl, itron, izar, kamheat, mkradio3, mkradio4, mkradio4a, multical21, qheat, qwater, rfmtx1, sharky774, topaseskr, ultrimis, unismart, vario451
[12:45:39][C][wmbus:421]: Meter:
[12:45:39][C][wmbus:422]: ID: 24650103 [0x01782177]
[12:45:39][C][wmbus:423]: Type: apator162
[12:45:39][C][wmbus:424]: Mode: T1
[12:45:39][C][wmbus:425]: Key: '00000000000000000000000000000000'
[12:45:39][C][wmbus:427]: Sensor '0x1782177 My lqi'
[12:45:39][C][wmbus:427]: Device Class: 'signal_strength'
[12:45:39][C][wmbus:427]: State Class: 'measurement'
[12:45:39][C][wmbus:427]: Unit of Measurement: ''
[12:45:39][C][wmbus:427]: Accuracy Decimals: 0
[12:45:39][C][wmbus:427]: Sensor '0x1782177 My RSSI'
[12:45:39][C][wmbus:427]: Unit of Measurement: 'dBm'
[12:45:39][C][wmbus:427]: Sensor '0x1782177 My cold water'
[12:45:39][C][wmbus:427]: Device Class: 'water'
[12:45:39][C][wmbus:427]: State Class: 'total_increasing'
[12:45:39][C][wmbus:427]: Unit of Measurement: 'm³'
[12:45:39][C][wmbus:427]: Accuracy Decimals: 3
[12:45:39][C][wmbus:427]: Icon: 'mdi:water'
[12:46:15][D][mbus:034]: Processing T1 A frame
[12:47:24][D][mbus:034]: Processing T1 A frame
nakładka Apator 16-2
i dalej nie wiem jak to ogarnąć.
Skąd wiesz, że
standardowe uruchomienie to 2 etapy
- uruchomienie sprzętu bez definiowania sensora i złapanie półsurowych telegramów w logach (oraz ewentualnie ich zdekodowanie na https://wmbusmeters.org/)
- dopisanie sekcji sensor po upewnieniu się, że znamy pasujący ID licznika/nakładki
Nie wiem czy dla tego modelu nakładki obecnie jest w ogóle potrzebny klucz (w sytuacji, gdy jest zerami, bo jeśli jest inny, to trzeba go podać).
bez sekcji
- sensor:
mam to samo w logach
[13:34:48][D][mbus:034]: Processing T1 A frame
[13:35:19][D][mbus:034]: Processing T1 A frame
Jak uzyję dongla usb DVBT i integracji Wmbusmeters to odczytuje mi stan bez problemu.
Received telegram from: 01782177
manufacturer: (APA) Apator, Poland (0x601)
type: Water meter (0x07) encrypted
ver: 0x05
device: rtlwmbus[00000001]
rssi: 127 dBm
driver: apator162
jednak chcialbym korzystac z cc1101
01782177
a czy 01782177= 0x1782177?
Wpadłem na to i wersję z 0 też testowałem.
Ale dlaczego bez zdefiniowanych senatorów nic nie mam?
Dobre pytanie, może zwiększ poziom logowania na jakiś verbose czy very_verbose
Zera na poczatku nie maja wplywu na dzialanie!! To jest urban-legend z innego kodu/integracji.
Daj VERBOSE i zapodaj logi. Jak daleko masz do wodomierza?
30cm
INFO Successfully connected to wmbus @ 192.168.0.196 in 0.011s
INFO Successful handshake with wmbus @ 192.168.0.196 in 2.777s
[14:46:27][I][app:102]: ESPHome version 2024.3.1 compiled on Mar 29 2024, 14:43:13
[14:46:27][C][wifi:580]: WiFi:
[14:46:27][C][wifi:408]: Local MAC: 08:3A:8D:D0:2F:2D
[14:46:27][C][wifi:413]: SSID: [redacted]
[14:46:27][C][wifi:416]: IP Address: 192.168.0.196
[14:46:27][C][wifi:419]: BSSID: [redacted]
[14:46:27][C][wifi:421]: Hostname: 'wmbus'
[14:46:27][C][wifi:423]: Signal strength: -52 dB ▂▄▆█
[14:46:27][V][wifi:425]: Priority: -7.0
[14:46:27][C][wifi:427]: Channel: 6
[14:46:27][C][wifi:428]: Subnet: 255.255.255.0
[14:46:27][C][wifi:429]: Gateway: 192.168.0.1
[14:46:27][C][wifi:430]: DNS1: 192.168.0.1
[14:46:27][C][wifi:431]: DNS2: 192.168.0.1
[14:46:27][C][logger:166]: Logger:
[14:46:27][C][logger:167]: Level: VERBOSE
[14:46:27][C][logger:169]: Log Baud Rate: 115200
[14:46:27][C][logger:170]: Hardware UART: UART0
[14:46:27][C][captive_portal:088]: Captive Portal:
[14:46:27][C][sntp:055]: SNTP Time:
[14:46:27][C][sntp:056]: Server 1: '0.pool.ntp.org'
[14:46:27][C][sntp:057]: Server 2: '1.pool.ntp.org'
[14:46:27][C][sntp:058]: Server 3: '2.pool.ntp.org'
[14:46:27][C][sntp:059]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[14:46:27][C][mdns:115]: mDNS:
[14:46:27][C][mdns:116]: Hostname: wmbus
[14:46:27][V][mdns:117]: Services:
[14:46:27][V][mdns:119]: - _esphomelib, _tcp, 6053
[14:46:27][V][mdns:121]: TXT: friendly_name = wmbus
[14:46:27][V][mdns:121]: TXT: version = 2024.3.1
[14:46:27][V][mdns:121]: TXT: mac = 083a8dd02f2d
[14:46:27][V][mdns:121]: TXT: platform = ESP8266
[14:46:27][V][mdns:121]: TXT: board = d1_mini
[14:46:27][V][mdns:121]: TXT: network = wifi
[14:46:27][V][mdns:121]: TXT: api_encryption = Noise_NNpsk0_25519_ChaChaPoly_SHA256
[14:46:27][C][ota:096]: Over-The-Air Updates:
[14:46:27][C][ota:097]: Address: wmbus.local:8266
[14:46:27][C][ota:100]: Using Password.
[14:46:27][C][ota:103]: OTA version: 2.
[14:46:27][C][api:139]: API Server:
[14:46:27][C][api:140]: Address: wmbus.local:6053
[14:46:27][C][api:142]: Using noise encryption: YES
[14:46:27][C][wmbus:372]: wM-Bus v3.2.1:
[14:46:27][C][wmbus:374]: Clients:
[14:46:27][C][wmbus:376]: wmbusmeters: 10.0.0.1:7227 TCP [rtl-wmbus]
[14:46:27][C][wmbus:389]: CC1101 frequency: 868.950 MHz
[14:46:27][C][wmbus:390]: CC1101 SPI bus:
[14:46:27][C][wmbus:391]: MOSI Pin: GPIO13
[14:46:27][C][wmbus:392]: MISO Pin: GPIO12
[14:46:27][C][wmbus:393]: CLK Pin: GPIO14
[14:46:27][C][wmbus:394]: CS Pin: GPIO15
[14:46:27][C][wmbus:395]: GDO0 Pin: GPIO5
[14:46:27][C][wmbus:396]: GDO2 Pin: GPIO4
[14:46:27][C][wmbus:403]: Available drivers: amiplus, apator08, apator162, apatoreitn, bmeters, c5isf, compact5, dme07, elf, evo868, fhkvdataiii, flowiq2200, hydrocalm3, hydrus, iperl, itron, izar, kamheat, mkradio3, mkradio4, mkradio4a, multical21, qheat, qwater, rfmtx1, sharky774, topaseskr, ultrimis, unismart, vario451
[14:47:05][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -33 dBm LQI: 128
[14:47:05][D][mbus:034]: Processing T1 A frame
[14:47:05][V][mbus:045]: Frame: 6B271C58D59A68E70B95358D599593C5C6AC4E696989D079A02BB32E1CA967C2D578D4D1CE7ACCC4BE3752FC045631CF0F1786907480AE68DC0CB131432D5F247009B4271C58D59A68E70B95358D599593C5C6AC4E56596696B193A92E66B199D578D4D1CE7ACCC4BE3752FC045631CF0F1786907480AE68DC0CB131432D5F247009B4271C58D59A68E70B95358D599593C5C6AC4E56596696B193A92E66B199637166399A58B59672726D29FC045631CF0F1786907480AE68DC0CB131432D (191) [RAW]
[14:47:05][V][3of6:083]: Decode 3 out of 6 failed..
[14:49:33][I][ota:117]: Boot seems successful, resetting boot loop counter.
[14:50:08][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -20 dBm LQI: 128
[14:50:08][D][mbus:034]: Processing T1 A frame
[14:50:08][V][mbus:045]: Frame: 6B271C58D59A4D338D4EC58D599593935AA44481CEED004FEC7CE3D51EBAB794B9665B2716C69CA372C9663992E6C6396999A7324F265C2D364D4CE34E374565B264D5271C58D59A4D338D4EC58D59959354D34E62E3596696B193D51EBAB794B9665B2716C69CA372C9663992E6C6396999A7324F265C2D364D4CE34E374565B264D5271C58D59A4D338D4EC58D59959354D34E62E3596696B193A970E9ACB168F19A9D2C2C9718A372C9663992E6C6396999A7324F265C2D364D4CE34E37 (191) [RAW]
[14:50:08][V][3of6:083]: Decode 3 out of 6 failed..
[14:50:20][V][rxLoop:167]: Have 120 bytes from CC1101 Rx, RSSI: -86 dBm LQI: 255
[14:50:20][D][mbus:034]: Processing T1 A frame
[14:50:20][V][mbus:045]: Frame: 7199A5C8B0902C032DA53E5BB3EF6F457F7FFC37F999C966A6B162E94E595959C3A93999B4732599C5A4E96594CEC7135964DB16B0E8D9B2597196C65366C5938D593799A5C8B0902C032DA53E5BB3EF6F457F3FFE0FFFD1FFF17FF84E595959C3A93999B4732599C5A4E96594CEC7135964DB16B0E8D9B2 (120) [RAW]
[14:50:20][V][3of6:083]: Decode 3 out of 6 failed..
moze problem jest w pinologi i zlutowaniu tego w calosc?
tutaj Very_verbose
INFO Successfully connected to wmbus @ 192.168.0.196 in 0.014s
INFO Successful handshake with wmbus @ 192.168.0.196 in 2.785s
[15:01:28][I][app:102]: ESPHome version 2024.3.1 compiled on Mar 29 2024, 14:59:24
[15:01:28][C][wifi:580]: WiFi:
[15:01:28][C][wifi:408]: Local MAC: 08:3A:8D:D0:2F:2D
[15:01:28][C][wifi:413]: SSID: [redacted]
[15:01:28][C][wifi:416]: IP Address: 192.168.0.196
[15:01:28][C][wifi:419]: BSSID: [redacted]
[15:01:28][C][wifi:421]: Hostname: 'wmbus'
[15:01:28][C][wifi:423]: Signal strength: -63 dB ▂▄▆█
[15:01:28][V][wifi:425]: Priority: 0.0
[15:01:28][C][wifi:427]: Channel: 6
[15:01:28][C][wifi:428]: Subnet: 255.255.255.0
[15:01:28][C][wifi:429]: Gateway: 192.168.0.1
[15:01:28][C][wifi:430]: DNS1: 192.168.0.1
[15:01:28][C][wifi:431]: DNS2: 192.168.0.1
[15:01:28][C][logger:166]: Logger:
[15:01:28][C][logger:167]: Level: VERY_VERBOSE
[15:01:28][C][logger:169]: Log Baud Rate: 115200
[15:01:28][C][logger:170]: Hardware UART: UART0
[15:01:28][C][captive_portal:088]: Captive Portal:
[15:01:28][C][sntp:055]: SNTP Time:
[15:01:28][C][sntp:056]: Server 1: '0.pool.ntp.org'
[15:01:28][C][sntp:057]: Server 2: '1.pool.ntp.org'
[15:01:28][C][sntp:058]: Server 3: '2.pool.ntp.org'
[15:01:28][C][sntp:059]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[15:01:28][C][mdns:115]: mDNS:
[15:01:28][C][mdns:116]: Hostname: wmbus
[15:01:28][V][mdns:117]: Services:
[15:01:28][V][mdns:119]: - _esphomelib, _tcp, 6053
[15:01:28][V][mdns:121]: TXT: friendly_name = wmbus
[15:01:28][V][mdns:121]: TXT: version = 2024.3.1
[15:01:28][V][mdns:121]: TXT: mac = 083a8dd02f2d
[15:01:28][V][mdns:121]: TXT: platform = ESP8266
[15:01:28][V][mdns:121]: TXT: board = d1_mini
[15:01:28][V][mdns:121]: TXT: network = wifi
[15:01:28][V][mdns:121]: TXT: api_encryption = Noise_NNpsk0_25519_ChaChaPoly_SHA256
[15:01:28][C][ota:096]: Over-The-Air Updates:
[15:01:28][C][ota:097]: Address: wmbus.local:8266
[15:01:28][C][ota:100]: Using Password.
[15:01:28][C][ota:103]: OTA version: 2.
[15:01:28][C][api:139]: API Server:
[15:01:28][C][api:140]: Address: wmbus.local:6053
[15:01:28][C][api:142]: Using noise encryption: YES
[15:01:28][C][wmbus:372]: wM-Bus v3.2.1:
[15:01:28][C][wmbus:374]: Clients:
[15:01:28][C][wmbus:376]: wmbusmeters: 10.0.0.1:7227 TCP [rtl-wmbus]
[15:01:28][C][wmbus:389]: CC1101 frequency: 868.950 MHz
[15:01:28][C][wmbus:390]: CC1101 SPI bus:
[15:01:28][C][wmbus:391]: MOSI Pin: GPIO13
[15:01:28][C][wmbus:392]: MISO Pin: GPIO12
[15:01:28][C][wmbus:393]: CLK Pin: GPIO14
[15:01:28][C][wmbus:394]: CS Pin: GPIO15
[15:01:28][C][wmbus:395]: GDO0 Pin: GPIO5
[15:01:28][C][wmbus:396]: GDO2 Pin: GPIO4
[15:01:28][C][wmbus:403]: Available drivers: amiplus, apator08, apator162, apatoreitn, bmeters, c5isf, compact5, dme07, elf, evo868, fhkvdataiii, flowiq2200, hydrocalm3, hydrus, iperl, itron, izar, kamheat, mkradio3, mkradio4, mkradio4a, multical21, qheat, qwater, rfmtx1, sharky774, topaseskr, ultrimis, unismart, vario451
[15:01:36][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=4294964144 (now=56848)
[15:01:39][VV][api.service:576]: on_ping_request: PingRequest {}
[15:01:39][VV][api.service:043]: send_ping_response: PingResponse {}
[15:01:41][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -35 dBm LQI: 128
[15:01:41][D][mbus:034]: Processing T1 A frame
[15:01:41][V][mbus:045]: Frame: 6B271C58D59A68E70B95358D5995939368A45B1A6E87694990F76B7BD7761A88281655EC3AB0938B4A8D3EF032D1A5D8E1561C36F796E60D85B8DE0251D40A46BE20271C58D59A68E70B95358D599593C5C6AC4E6963596696B1937BD7761A88281655EC3AB0938B4A8D3EF032D1A5D8E1561C36F796E60D85B8DE0251D40A46BE20271C58D59A68E70B95358D599593C5C6AC4E6963596696B1938D2CE8CD2DA35C971C535366938B4A8D3EF032D1A5D8E1561C36F796E60D85B8DE0251D4 (191) [RAW]
[15:01:41][V][3of6:083]: Decode 3 out of 6 failed..
[15:02:08][VV][api.service:576]: on_ping_request: PingRequest {}
[15:02:08][VV][api.service:043]: send_ping_response: PingResponse {}
[15:02:19][VV][api.service:576]: on_ping_request: PingRequest {}
[15:02:19][VV][api.service:043]: send_ping_response: PingResponse {}
[15:02:36][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=56848 (now=116848)
[15:02:59][VV][api.service:576]: on_ping_request: PingRequest {}
[15:02:59][VV][api.service:043]: send_ping_response: PingResponse {}
[15:03:08][VV][api.connection:132]: Sending keepalive PING...
[15:03:08][VV][api.service:037]: send_ping_request: PingRequest {}
[15:03:08][VV][api.service:585]: on_ping_response: PingResponse {}
[15:03:15][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -25 dBm LQI: 128
[15:03:15][D][mbus:034]: Processing T1 A frame
[15:03:15][V][mbus:045]: Frame: 6B271C58D59A4D338D4EC58D599593935A7C4746E22012BF6E6F843751E4A47A53B7AFCD2CB90DA3012D85F1C8DA69D23D2CD2564E8CBB1971A8D658D8E6D2555C9695271C58D59A4D338D4EC58D59959354D34E6719596696B1963751E4A47A53B7AFCD2CB90DA3012D85F1C8DA69D23D2CD2564E8CBB1971A8D658D8E6D2555C9695271C58D59A4D338D4EC58D59959354D34E6719596696B196B25A9C562F464E3742E6E670D7A3012D85F1C8DA69D23D2CD2564E8CBB1971A8D658D8E6 (191) [RAW]
[15:03:15][V][3of6:083]: Decode 3 out of 6 failed..
[15:03:26][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -42 dBm LQI: 128
[15:03:26][D][mbus:034]: Processing T1 A frame
[15:03:26][V][mbus:045]: Frame: 6B271C58D59A68E70B95358D59959393C58330D59FFFDFAFE2AC100B7ED5B6E01074B2C9635964E638B671972A698F2671C59C636A6C9CD25A4B6A9C6C5A65672C2F1C271C58D59A68E70B95358D599593C6AC4E6974596696B19B1A7ED5B6E01074B2C9635964E638B671972A698F2671C59C636A6C9CD25A4B6A9C6C5A65672C2F1C271C58D59A68E70B95358D599593C6AC4E6974596696B19B1A9B468DC74B23A53A636394D4E638B671972A698F2671C59C636A6C9CD25A4B6A9C6C5A (191) [RAW]
[15:03:26][V][3of6:083]: Decode 3 out of 6 failed..
[15:03:36][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=116848 (now=176848)
[15:03:39][VV][api.service:576]: on_ping_request: PingRequest {}
[15:03:39][VV][api.service:043]: send_ping_response: PingResponse {}
[15:04:08][VV][api.service:576]: on_ping_request: PingRequest {}
[15:04:08][VV][api.service:043]: send_ping_response: PingResponse {}
[15:04:18][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -40 dBm LQI: 128
[15:04:18][D][mbus:034]: Processing T1 A frame
[15:04:18][V][mbus:045]: Frame: 6B271C58D59A68E70B95358D599593C5C6ACAC4E4EFF48AC309AC2E6B32A6C5A5356CAC8ECB298E972338D2D9CB1956C65D16974B31B1C5998F24CD672D1359723A5AB271C58D59A68E70B95358D599593C5C6AC6971596696B19C4E97476C5A5356CAC8ECB298E972338D2D9CB1956C65D16974B31B1C5998F24CD672D1359723A5AB271C58D59A68E70B95358D599593C5C6AC6971596696B19C4E974731CA6CB1A5C6B1B1969A6B6B2C338D2D9CB1956C65D16974B31B1C5998F24CD672 (191) [RAW]
[15:04:18][V][3of6:083]: Decode 3 out of 6 failed..
[15:04:19][VV][api.service:576]: on_ping_request: PingRequest {}
[15:04:19][VV][api.service:043]: send_ping_response: PingResponse {}
[15:04:36][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=176848 (now=236848)
[15:04:45][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -25 dBm LQI: 128
Jeszcze inaczej: 0x01782177
Wywal clients i dodaj sync_mode.
Dlaczego upieracie sie na to zero z przodu? To nie ma znaczenia. Wazne jest tylko 0x albo jego brak. Czyli inaczej HEX czy DEC
Kiedyś jak testowałem i musialo w ID być 8 cyfr, inaczej nie czytał. Może sie zmieniło
Napewno nie na moim komponencie. On zawsze był zero-agnostyczny. ![]()
Nic to nie dało, logi wyglądają tak samo.
SPI wyglada ze jest dobrze podlaczone. Mozesz jeszcze spróbować zamienic miejscami GDO 0 i 2
[16:41:56][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=476929 (now=536929)
[16:41:58][VV][api.service:576]: on_ping_request: PingRequest {}
[16:41:58][VV][api.service:043]: send_ping_response: PingResponse {}
[16:42:01][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -40 dBm LQI: 128
[16:42:01][D][mbus:034]: Processing T1 A frame
[16:42:01][V][mbus:045]: Frame: 6B271C58D59A68E70B95358D599593C5C6AC4E6C9A596696B19CB4666D29653A5AC93959B0B4CD6A699A94E3B4D1659C9B44DC6567169B47268D665C2E6C743B22D665C66C9A96565A36ACC662D62D673466969A5A32E9C6671CD2C58EB29C6C2EC9B44EC7199A5599A6935C7133B26639638DAA72CA3A65D237169A68E6C742D99A38CDC53CA5CB44F18E6B294D6B1C5A9971D2335C96CCAC70D69C9B464B36C8F498BCAC356A5CD34B264E3C562CB98D4D92CB9635A665C58B73471364D5 (191) [RAW]
[16:42:01][VV][3of6:095]: Decode 3 out of 6 OK.
[16:42:01][V][mbus:052]: Frame: 6E440106624397010507D4687AE6006085EC5ACF57F6E79583716AA6922CC004AC745040AC4AB0543ADC2E305458AF500B68DA30304C5F660B3FDA44C8028FD838AC7845A905FF14472E5B9BB6FEEBF9CB40AABADC35ABB1D7E9EC7DBA8F70840F9DCB1498E84164AC5318BCA3E810F4CC8A7BD033A175339B0A54034C4751 (127) [with CRC]
[16:42:01][V][mbus:095]: Validating CRC for Block1
[16:42:01][V][crc:031]: calculated: 0xD468, read: 0xD468
[16:42:01][V][mbus:115]: Validating CRC for Block2
[16:42:01][V][crc:031]: calculated: 0x922C, read: 0x922C
[16:42:01][V][mbus:115]: Validating CRC for Block3
[16:42:01][V][crc:031]: calculated: 0xAF50, read: 0xAF50
[16:42:01][V][mbus:115]: Validating CRC for Block4
[16:42:01][V][crc:031]: calculated: 0x38AC, read: 0x38AC
[16:42:01][V][mbus:115]: Validating CRC for Block5
[16:42:01][V][crc:031]: calculated: 0xAABA, read: 0xAABA
[16:42:01][V][mbus:115]: Validating CRC for Block6
[16:42:01][V][crc:031]: calculated: 0x98E8, read: 0x98E8
[16:42:01][V][mbus:115]: Validating CRC for Block7
[16:42:01][V][crc:031]: calculated: 0x7533, read: 0x7533
[16:42:01][V][mbus:115]: Validating CRC for Block8
[16:42:01][V][crc:031]: calculated: 0x4751, read: 0x4751
[16:42:01][V][mbus:062]: Frame: 6E4401066243970105077AE6006085EC5ACF57F6E79583716AA6C004AC745040AC4AB0543ADC2E3054580B68DA30304C5F660B3FDA44C8028FD87845A905FF14472E5B9BB6FEEBF9CB40DC35ABB1D7E9EC7DBA8F70840F9DCB144164AC5318BCA3E810F4CC8A7BD033A19B0A54034C (111) [without CRC]
[16:42:01][VV][wmbus:061]: Have data from CC1101 ...
[16:42:01][D][wmbus:176]: Meter ID [0x01974362] RSSI: -40 dBm LQI: 128 Frame: T1 A not found in configuration T: 6E4401066243970105077AE6006085EC5ACF57F6E79583716AA6C004AC745040AC4AB0543ADC2E3054580B68DA30304C5F660B3FDA44C8028FD87845A905FF14472E5B9BB6FEEBF9CB40DC35ABB1D7E9EC7DBA8F70840F9DCB144164AC5318BCA3E810F4CC8A7BD033A19B0A54034C (111)
[16:42:01][W][component:232]: Component wmbus took a long time for an operation (212 ms).
[16:42:01][W][component:233]: Components should block for at most 30 ms.
[16:42:25][V][rxLoop:167]: Have 191 bytes from CC1101 Rx, RSSI: -38 dBm LQI: 128
No i GIT
zadziałało.
"total_m3":186.579
to jak teraz skonfigurowac -sernsor:
bo podaje rozne kobinacje i mam
[17:25:02][D][mbus:034]: Processing T1 A frame
[17:25:02][D][wmbus:090]: Using driver 'apator162' for ID [0x01782177] RSSI: -36 dBm LQI: 128 Frame: T1 A T: 6E4401067721780105077AAF0060851D39CE343C306A98D68615B837A6C79E36DB360F85782B05A504F4DDEC2DDF390142E698F10148F7134A4905A07A84A9B4CEE14C48BAB585D2E9299BE52F121A8DF8DFD5EB9F2030299FCF52B916DFA1253D76DA9B472854F5E0A15CF33395A4 (111)
[17:25:02][D][wmbus:161]: Can't get value(s) from telegram for ID [0x01782177]
No ale w logu to ja widzę
0x01974362
a nie
0x01782177
są 2 nakładki
0x01974362 oraz 0x01782177
korzystać bede z 0x01782177
