Powiadomienie o dostępnych aktualizacjach w HA i HACS
Jeżeli będą jakieś aktualizacje zostaną one automatycznie wyświetlona w powiadomieniach na pasku bocznym .
Plik ha_monitor_sensors.yaml umieszczamy w katalogu packages
Jak umieszczać pliki w katalogu packages
@macek https://forum.arturhome.pl/t/package-w-home-assistant/707
# https://community.home-assistant.io/t/update-notifications-core-hacs-supervisor-and-addons/182295
# Sensor to track available updates for supervisor & addons
- platform: command_line
name: Updater Supervisor
command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"update_available":.data.update_available,"addons":[.data.addons[] | select(.update_available)]}'''
scan_interval: 600
value_template: "{{ value_json.addons | length }}"
unit_of_measurement: pending update(s)
json_attributes:
- update_available
- newest_version
- current_version
- addons
# Alternate updater sensor for core since binary_sensor.updater is very slow to recognize updates
command: 'curl http://supervisor/core/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version}'''
scan_interval: 600
value_template: "{% if value_json.newest_version != value_json.current_version %}on{% else %}off{% endif %}"
json_attributes:
- newest_version
- current_version
# https://community.home-assistant.io/t/update-notifications-core-hacs-supervisor-and-addons/182295/104
command: 'curl http://supervisor/os/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"update_available":.data.update_available}'''
value_template: "{% if value_json.update_available or value_json.newest_version != value_json.current_version %}on{% else %}off{% endif %}"
json_attributes:
- newest_version
- current_version
- update_available
automation:
- alias: Updates Pending
mode: restart
trigger:
- platform: state
entity_id: sensor.updater_core
- platform: state
entity_id: sensor.updater_hassos
- platform: state
entity_id: sensor.updater_supervisor
- platform: state
entity_id: sensor.hacs
- platform: homeassistant
event: start
action:
- alias: "Update Persistent Notification"
choose:
conditions:
- condition: or
conditions:
- condition: template
value_template: "{{ states('sensor.updater_core') == 'on' }}"
value_template: "{{ states('sensor.updater_hassos') == 'on' }}"
value_template: "{{ (states('sensor.updater_supervisor') | float) != 0 }}"
value_template: "{{ (states('sensor.hacs') | float) != 0 }}"
sequence:
- service: persistent_notification.create
data_template:
title: Updates Pending
message: |
{% set core_entity_id = 'sensor.updater_core' %}
{% set os_entity_id = 'sensor.updater_hassos' %}
{% if states(core_entity_id) == 'on' or states(os_entity_id) == 'on' %}
[Home Assistant](/hassio/dashboard)
{% if states(core_entity_id) == 'on' %}
* **Core** {{ state_attr(core_entity_id,"current_version") }} -> {{ state_attr(core_entity_id,"newest_version") }} [`PRE-CHECK LOG`](/hassio/addon/core_check_config/logs)
{% endif %}
{% if states(os_entity_id) == 'on' %}
* **OS** {{ state_attr(os_entity_id,"current_version") }} -> {{ state_attr(os_entity_id,"newest_version") }}
{% endif %}
{% endif %}
{% set supervisor_entity_id = 'sensor.updater_supervisor' %}
{% if (states(supervisor_entity_id) | float) != 0 %}
[Add-ons](/hassio/dashboard)
{% for addon in state_attr(supervisor_entity_id, 'addons') %}
* [**{{ addon.name }}**](/hassio/addon/{{ addon["slug"] }}/info) {{ addon["version"] }} -> {{ addon["version_latest"] }}
{% endfor %}
{% endif %}
{% set hacs_entity_id = 'sensor.hacs' %}
{% if (states(hacs_entity_id) | float) != 0 %}
[HACS](/hacs/entry)
{% for repo in state_attr(hacs_entity_id, 'repositories') %}
* **{{ repo.display_name }}** {{ repo["installed_version"] }} -> {{ repo["available_version"] }}
{% endfor %}
{% endif %}
notification_id: "updates_pending"
default:
- service: persistent_notification.dismiss
- alias: Check Home Assistant Configuration
mode: single
trigger:
- platform: state
to: 'on'
action:
- service: hassio.addon_start
addon: core_check_config
