Ostatni raz w HA bawiłem się dwa lata temu. Teraz przeprowadziłem się na nowe i chciałbym sobie pospinać kilka urządzeń.
Próbuję zainstalować HA z tego obrazu :
I niestety dostaję błąd po instalacji (po wejściu w adres IP na który wysyła mnie zainstalowany HA)
cont-init: info: running /etc/cont-init.d/udev.sh
[18:42:55] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[18:42:55] INFO: Starting local supervisor watchdog...
23-11-13 18:43:02 INFO (MainThread) [__main__] Initializing Supervisor setup
23-11-13 18:43:02 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-11-13 18:43:02 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: generic-x86-64
23-11-13 18:43:02 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.10.0
23-11-13 18:43:02 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-11-13 18:43:03 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-11-13 18:43:03 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-13 18:43:03 INFO (MainThread) [__main__] Setting up Supervisor
23-11-13 18:43:03 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-11-13 18:43:03 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-11-13 18:43:03 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-11-13 18:43:04 INFO (MainThread) [supervisor.host.services] Updating service information
23-11-13 18:43:04 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-11-13 18:43:04 INFO (MainThread) [supervisor.host.network] Updating local network information
23-11-13 18:43:05 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-11-13 19:43:05 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-11-13 19:43:05 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-11-13 19:43:05 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-11-13 19:43:05 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
23-11-13 19:43:05 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-11-13 19:43:06 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
23-11-13 19:43:06 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-11-13 19:43:06 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-11-13 19:43:06 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-11-13 19:43:09 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-11-13 19:43:09 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-11-13 19:43:09 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-11-13 19:43:09 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
23-11-13 19:43:09 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-11-13 19:43:11 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
23-11-13 19:43:11 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-11-13 19:43:11 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-11-13 19:43:11 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-11-13 19:43:14 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-11-13 19:43:14 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-11-13 19:43:14 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-11-13 19:43:14 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-11-13 19:43:15 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-11-13 19:43:15 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-11-13 19:43:15 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/generic-x86-64-homeassistant
23-11-13 19:43:15 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/generic-x86-64-homeassistant found.
23-11-13 19:43:15 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
23-11-13 19:43:15 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-11-13 19:43:15 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-11-13 19:43:15 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-11-13 19:43:17 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
23-11-13 19:43:17 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
23-11-13 19:43:17 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-11-13 19:43:17 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-11-13 19:43:17 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-11-13 19:43:22 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Could not resolve host: github.com
23-11-13 19:43:22 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-11-13 19:43:22 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
23-11-13 19:43:22 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-11-13 19:43:22 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Could not resolve host: github.com
23-11-13 19:43:22 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-11-13 19:43:22 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
23-11-13 19:43:22 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-11-13 19:43:22 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][3]. Got 'homeassistant_config:rw'
23-11-13 19:43:23 INFO (MainThread) [supervisor.store] Loading add-ons from store: 27 all - 27 new - 0 remove
23-11-13 19:43:23 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-11-13 19:43:23 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-11-13 19:43:23 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-11-13 19:43:23 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-11-13 19:43:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-11-13 19:43:23 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-11-13 19:43:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-11-13 19:43:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-13 19:43:23 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-11-13 19:43:23 INFO (MainThread) [__main__] Running Supervisor
23-11-13 19:43:23 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-11-13 19:43:23 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
23-11-13 19:43:23 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-11-13 19:43:23 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.11.0
23-11-13 19:43:23 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2023.11.0.
23-11-13 19:49:38 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.11.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.module] Create new issue update_failed - supervisor / None
23-11-13 19:49:38 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.11.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-11-13 19:49:38 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
23-11-13 19:49:38 INFO (MainThread) [supervisor.addons] Phase 'initialize' starting 0 add-ons
23-11-13 19:49:38 INFO (MainThread) [supervisor.addons] Phase 'system' starting 0 add-ons
23-11-13 19:49:38 INFO (MainThread) [supervisor.addons] Phase 'services' starting 0 add-ons
23-11-13 19:49:38 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-11-13 19:49:38 INFO (MainThread) [supervisor.addons] Phase 'application' starting 0 add-ons
23-11-13 19:49:38 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-11-13 19:49:38 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-11-13 19:49:38 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-11-13 19:49:38 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.11.2
23-11-13 19:49:38 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.11.2.
23-11-13 19:49:38 INFO (MainThread) [supervisor.host.info] Updating local host information
23-11-13 19:49:38 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-11-13 19:49:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-11-13 19:49:39 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-13 19:49:39 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
23-11-13 19:49:39 INFO (MainThread) [supervisor.host.services] Updating service information
23-11-13 19:49:39 INFO (MainThread) [supervisor.host.network] Updating local network information
23-11-13 19:49:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-11-13 19:49:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
Sprzęt to : Dell Wyse Dx0D. Próbowałem z innego pendrive i na innym dysku. Nadal to samo. Może coś widzicie w logach bo ciężko mi to rozszyfrować ![]()
W między czasie inne kopać google
Z góry dziękuję za pomoc ![]()
