22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
22-04-10 12:41:07 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2mqtt (45df7312_zigbee2mqtt)
Przede wszystkim czytać jakie zmiany przynosi nowa wersja.
Od 1.25 .0-1 należy usunąć konfigurację Z2M (wpisy które zamieściłeś w logu) z konfiguracji dodatku.
Most Zigbee2MQTT configuration is now done in Zigbee2MQTT directly (either via the UI or by modifying the configuration file, usually /config/zigbee2mqtt/configuration.yaml, directly).
As Zigbee2MQTT won't start with an MQTT server or serial adapter you must configure these through the add-on configuration page before you can start Zigbee2MQTT for the first time.
Existing installations should be able to safely remove the Zigbee2MQTT configuration from the add-on configuration as these values should have already been persisted to the configuration file.
Aby dokonać tej skomplikowanej operacji należy w zakładce “Konfiguracja” wybrać “Dodatki, kopie zapasowe oraz supervisior” wejść do Zigbee2mqtt w którym wybieramy zakładkę “Konfiguracja”
Pomożecie mi z uruchomieniem po aktualizacji interfejsu użytkownika z2mqtt? Po aktualizacji nie chce się załadować, powinienem gdzieś coś w config.yaml uzupełnić?
@Mateusz ten powrót do ustawień domyślny powinieneś raczej wykonać po aktualizacji jeśli masz backup to przywróć później aktualizacja i dopiero powrócić do ustawień domyślnych
Szkoda, że nie skopiowałeś logów z 5 rano.
Bo “nagle przestało działać” ma zwykle wiele oblicz, a jednym z nich jest np. skutek uboczny aktualizacji, ale przyczyn może być bardzo wiele.
Masz włączoną auto-aktualizację tego Dodatku?
Czytasz i dalej robisz po swojemu i oczekujesz innych rezultatów.
Kto Ci kazał wpisać do konfigu IP serwera ?
Dwa dlaczego nie aktualizujesz Z2M skoro na ZHA widzi ?
A skoro widzi to usiądź i zaktualizuj Z2M ,ZHA odinstaluj bo nie mogą te rzeczy chodzić naraz ( nie , to nie Windows że się samo zrobi ).
A samo HA aktualizujesz czy też wersja prehistoryczna ?
nic wcześniej nie wspomniałeś o tym, że HA jest na Proxmoxie więc aby Conbee2 działało poprawnie w HA musi być poprawnie obsługiwane w Proxmoxie, oj taki mały szczegół w opisywaniu problemu .
Co mogło być powodem restartu usługi Z2M o takiej porze? Czy w tym czasie zrestartowal się także HA a może cała wirtualna maszyna z HA? A może cały host (serwer) z Proxmoxem?
To wygląda na problem z plikiem bazy Z2M, odczyt wywalił sie na odczycie na samym początku pliku bazy, takie problemy występują przy twardym restarcie (np. brak zasilania). Wystarczyło odtworzyć z backupu sam dodatek Z2M i wszystko powinno również działać poprawnie.
