Samba NAS dostęp do dysku USB
Witam
czytam czytam i nie mogę sobie poradzić z tematem
system Haos generic
1 zainstalowalem Sambanas
2.podpiełem dysk usb
a nadałem mu etykietę my book
b format ext4 bo nie widzi nffs
c w konfiguracji dodatku dodałem w moredisks: dysk z etykietę MY BOOK
3.Pojawiły mi sie encje dysków
sensor.sambanas_device_name_dev_sda_sat (wewnetrzny
sensor.sambanas_device_name_dev_sdb_sat (podpiety usb)
logi z samby
[01:50:20] INFO: MoreDisks to mount:
	WD
	MY BOOK
[01:50:20] INFO: Automount is Enabled!
[01:50:20] INFO: Mounting disks:
	MY BOOK
	WD
	WD SmartWare
[01:50:20] INFO: Mounting MY BOOK of type ext4
[01:50:20] INFO: Mount MY BOOK[ext4] Success!
[01:50:20] WARNING: Your WD is ntfs. This is an EXPERIMENTAL support
mount: /mnt/WD: unknown filesystem type 'ntfs3'.
       dmesg(1) may have more information after failed mount system call.
[01:50:20] WARNING: Fail to mount WD!
[01:50:20] INFO: Mounting WD SmartWare of type udf
mount: /mnt/WD SmartWare: unknown filesystem type 'udf'.
[01:50:20] WARNING: Fail to mount WD SmartWare!
s6-rc: info: service init-automount successfully started
s6-rc: info: service init-smartd: starting
s6-rc: info: service init-samba: starting
s6-rc: info: service hd-idle: starting
s6-rc: info: service hd-idle successfully started
[01:50:21] INFO: Enabling S.M.A.R.T for /dev/sda
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-5.15.90] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
[01:50:21] INFO: Hostname: homeassistant
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Enabled.
SMART Attribute Autosave Enabled.
SMART Automatic Offline Testing Enabled every four hours.
[01:50:21] INFO: Enabling S.M.A.R.T for /dev/sdb
[01:50:21] INFO: Interfaces: enp1s0
SMART Enabled.
s6-rc: info: service init-smartd successfully started
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
Added user sambanas.
[01:50:21] INFO: Exposed Disks Summary:
[config]                path = /config
[addons]                path = /addons
[ssl]                   path = /ssl
[share]                 path = /share
[backup]                path = /backup
[media]                 path = /media
[MY BOOK]               path = /mnt/MY BOOK
teoretycznie powinienem mieć dostęp ale jak wejdę w otoczenie sieciowe windowsa to brakuje [MY BOOK] reszta jest
dla testów zostawiłem partycje nfnfs z etykieta WD co w logach widać ze nie montuje
mam nadzieje ze w miarę spójnie napisałem zważywszy na porę
Pytanie jak mam dostać się do My Book
Spróbuj wpisać ten udział ręcznie w linijce otoczenia sieciowego
Screenshot - 15.04.2023 , 09_42_36
Udziały staraj się dodawać bez spacji MY_BOOK
@ropian podstawowa stara zasada administratorów mówi: nigdy nie używamy spacji w nazwach katalogów (eliminujemy w ten sposób mnóstwo problemów). Dodatkowo w systemie linux używamy małych liter (bo wielkość liter ma znaczenie) dlatego proponuje zamienić wszędzie ciąg znaków MY BOOK na np. mybook i wróćmy ewentualnie do analizy problemu.
strasznie nie lubię gdy się samo cos naprawia bo nawet nie wiem co było przyczyną.
Na dana chwile
na windowsie
loguje sie kontem do sambanas
i moim oczom ukazuje się widok dysku MY BOOK
co ciekawe format jest ntfs i cos zjadło 24GB a w środku jest tylko pusty katalog lost+found
logi z samby
martwi mnie komunikat
sys_path_to_bdev() failed for path [.]!
2023-04-15 12:11:59,174:wsdd INFO(pid 346): 192.168.1.13:56121(enp1s0) - - "Hello urn:uuid:6b876893-e7a8-42e9-ae2f-5c797744f903 UDP" - -
2023-04-15 12:11:59,175:wsdd INFO(pid 346): fe80::3170:e33a:ab00:fbc0:56122(enp1s0) - - "Hello urn:uuid:119c0826-a52e-4e98-afca-ea460058c07a UDP" - -
2023-04-15 12:12:00,210:wsdd INFO(pid 346): fe80::3170:e33a:ab00:fbc0:58720(enp1s0) - - "Probe urn:uuid:c0f3f1f1-bb0b-4be5-9b4a-ab7836bf0305 UDP" - -
2023-04-15 12:12:00,295:wsdd INFO(pid 346): fe80::3170:e33a:ab00:fbc0:55039(enp1s0) - - "Resolve urn:uuid:a055e374-c5fc-496e-90b2-9ed96ac8f4dd UDP" - -
2023-04-15 12:12:00,309:wsdd INFO(pid 346): fe80::3170:e33a:ab00:fbc0 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 12:12:09,202:wsdd INFO(pid 346): fe80::3170:e33a:ab00:fbc0:58720(enp1s0) - - "Resolve urn:uuid:634482a0-2f5f-40a5-b635-7af7ffb20369 UDP" - -
2023-04-15 12:53:01,882:wsdd INFO(pid 346): 192.168.1.30:63375(enp1s0) - - "Probe urn:uuid:bed96d32-b48d-4fb9-b27b-a55171d15409 UDP" - -
2023-04-15 12:53:01,945:wsdd INFO(pid 346): 192.168.1.30:58682(enp1s0) - - "Resolve urn:uuid:ac39f492-d23c-44da-acf5-1d9cd2605b86 UDP" - -
2023-04-15 12:53:01,973:wsdd INFO(pid 346): 192.168.1.30 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 12:53:12,169:wsdd INFO(pid 346): 192.168.1.30:63375(enp1s0) - - "Resolve urn:uuid:3cb9076d-de1a-411d-b5f5-0277c05fa4a4 UDP" - -
2023-04-15 12:53:28,410:wsdd INFO(pid 346): 192.168.1.30:64511(enp1s0) - - "Hello urn:uuid:52e0c844-b04f-4555-9d85-86cc0ca47d4a UDP" - -
2023-04-15 12:53:28,410:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:64512(enp1s0) - - "Hello urn:uuid:f991f6e5-38d9-4533-80f3-df3f848058ab UDP" - -
2023-04-15 12:54:49,613:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:62695(enp1s0) - - "Probe urn:uuid:3218f90d-527c-4db2-ab33-6277a840624d UDP" - -
2023-04-15 12:54:49,674:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:62697(enp1s0) - - "Resolve urn:uuid:cee55af5-862f-4507-8ced-21d4686dbddf UDP" - -
2023-04-15 12:54:49,677:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
create_connection_session_info: guest user (from session setup) not permitted to access this share (MY BOOK)
create_connection_session_info failed: NT_STATUS_ACCESS_DENIED
2023-04-15 13:03:14,676:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:64512(enp1s0) - - "Bye urn:uuid:15b044e4-b2e5-45e9-b19e-b8e12ad4b3ee UDP" - -
2023-04-15 13:03:40,363:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:54062(enp1s0) - - "Hello urn:uuid:bd8f6690-5497-4caf-9b5a-9b568df8a14a UDP" - -
2023-04-15 13:03:40,364:wsdd INFO(pid 346): 192.168.1.30:54061(enp1s0) - - "Hello urn:uuid:ea5ccc8b-007c-4821-8f6d-48904b5e4ecc UDP" - -
2023-04-15 13:03:40,895:wsdd INFO(pid 346): 192.168.1.30:57946(enp1s0) - - "Resolve urn:uuid:9bc92e4b-4cf8-49e8-aa16-ee149d0bc1c6 UDP" - -
2023-04-15 13:03:40,896:wsdd INFO(pid 346): 192.168.1.30:57946(enp1s0) - - "Probe urn:uuid:ac2255b0-6433-4a2d-85ea-b3f7f75c0eb8 UDP" - -
2023-04-15 13:03:40,957:wsdd INFO(pid 346): 192.168.1.30:50707(enp1s0) - - "Resolve urn:uuid:07847233-488f-4337-81f6-fc0bdab18d72 UDP" - -
2023-04-15 13:03:40,967:wsdd INFO(pid 346): 192.168.1.30 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 13:03:41,410:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:54062(enp1s0) - - "Hello urn:uuid:7d97c8dd-3780-4757-a294-188528be45c1 UDP" - -
2023-04-15 13:03:41,412:wsdd INFO(pid 346): 192.168.1.30:54061(enp1s0) - - "Hello urn:uuid:71978b08-3a82-4f6b-92a4-8da1f9f38f69 UDP" - -
2023-04-15 13:03:41,441:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:54062(enp1s0) - - "Hello urn:uuid:5766b47a-4296-485c-bdd4-903036c3d0b5 UDP" - -
2023-04-15 13:03:41,442:wsdd INFO(pid 346): 192.168.1.30:54061(enp1s0) - - "Hello urn:uuid:81afcaf3-a664-4eb1-a34a-a1e837366705 UDP" - -
2023-04-15 13:03:42,206:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:57947(enp1s0) - - "Resolve urn:uuid:397584c3-0289-4d2c-8be6-d3b51776cff2 UDP" - -
2023-04-15 13:03:43,800:wsdd INFO(pid 346): 192.168.1.30:54061(enp1s0) - - "Hello urn:uuid:d0e624fa-12ef-488f-8d26-fbbd5a1b74e6 UDP" - -
2023-04-15 13:03:43,801:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:54062(enp1s0) - - "Hello urn:uuid:a7f84389-2e6b-4098-aa43-81414919ce66 UDP" - -
2023-04-15 13:03:53,807:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:57947(enp1s0) - - "Resolve urn:uuid:b97d2797-b90a-42d9-9606-1de95ac62cfa UDP" - -
2023-04-15 13:03:56,229:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:52344(enp1s0) - - "Probe urn:uuid:2cfb8c7b-7093-4f0d-8901-9bbe23c7c0ec UDP" - -
2023-04-15 13:03:56,291:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:52346(enp1s0) - - "Resolve urn:uuid:a28b5c5d-8ba1-47f0-b0bb-3ca1fcd79fb3 UDP" - -
2023-04-15 13:03:56,296:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 13:13:47,073:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:60643(enp1s0) - - "Probe urn:uuid:3f52f4f8-86ce-44c7-b19a-77e7a9a59d30 UDP" - -
2023-04-15 13:13:47,135:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57:49610(enp1s0) - - "Resolve urn:uuid:ca9025a4-5a1a-4ff0-8e13-bd51ce766dfd UDP" - -
2023-04-15 13:13:47,141:wsdd INFO(pid 346): fe80::5bc:a3e3:d9d8:dc57 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 13:15:08,219:wsdd INFO(pid 346): fe80::3170:e33a:ab00:fbc0:56122(enp1s0) - - "Bye urn:uuid:cff395f6-37e5-4e4c-8603-13335dc88f07 UDP" - -
zrobiłem restart home asistanta co by sprawdzić czy cos się nie wywali odpaliłem jeszcze raz Windowsa i jak na razie wszystko działa
moge kopiowac pilik znienac i usuwać
Ukryte pliki :thinking:
veto_files:
  - "._*"
tak to jest jak człowiek się nie zna i cos próbuje zrobić :slight_smile:
niestety przewija się w logach ten błąd
da się to wyeliminować? czy to moze byc wina ze na dysku mam 2 partycje
i wywala błąd
A ja bym powiedział, ze masz 3 partycje:
	MY BOOK
	WD
	WD SmartWare
W opcje podmontowania dyskow również jakieś nieścisłości:
Osobiście, przy takim “misz-masz”, nie używałbym tego dysku do przechowywania danych. Nie wiem jaki masz cel trzymania kilku różnych partycji na dysku więc trudno coś jednoznacznie doradzić.
Trochę mi zajęło
mam dysk wd zgranym samrtware i za cholerę nie dało sie tego usunąć .na szczęście w końcu znalazlem info jak sie tego pozbyć ( na ubuntu formatowałem dysk)
na partycji Wd miałem 300 GB danych musiałem skopiować sobie przed formatem.
Zmieniłem na małe litery i bez spacji , cofnąłem się tez kilka backup w tył
podsumowując
Supported fs: ext3 ext2 ext4 squashfs vfat msdos iso9660 btrfs
[23:10:09] INFO: MediaLibrary disabled in config. Disk are mounted only for this addon!
[23:10:09] INFO: Available Disk Labels:
[23:10:09] INFO: 	mybook[ext4]
[23:10:10] INFO: MoreDisks to mount:
	mybook
[23:10:10] INFO: Automount is Enabled!
[23:10:10] INFO: Mounting disks:
	mybook
[23:10:10] INFO: Mounting mybook of type ext4
[23:10:10] INFO: Mount mybook[ext4] Success!
[23:10:10] INFO: Enabling S.M.A.R.T for /dev/sda
[23:10:10] INFO: Hostname: homeassistant
SMART Enabled.
[23:10:10] INFO: Enabling S.M.A.R.T for /dev/sdb
[23:10:10] INFO: Interfaces: enp1s0
SMART Enabled.
Added user homeassistant.
[23:10:11] INFO: Exposed Disks Summary:
[ssl]                   path = /ssl
[mybook]                path = /mnt/mybook
s6-rc: info: service init-samba successfully started
s6-rc: info: service init-mqtt: starting
s6-rc: info: service wsdd: starting
s6-rc: info: service smbd: starting
s6-rc: info: service nmbd: starting
s6-rc: info: service avahi: starting
s6-rc: info: service smbd successfully started
s6-rc: info: service nmbd successfully started
s6-rc: info: service wsdd successfully started
s6-rc: info: service avahi successfully started
nmbd version 4.16.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2022
smbd version 4.16.8 started.
INFO: Profiling support unavailable in this build.
[23:10:11] INFO: Starting the AVAHI for homeassistant...
Waiting for daemon ...
[23:10:11] INFO: Starting the wsdd daemon for Domek/homeassistant...
[23:10:11] INFO: Interfaces: -i enp1s0
2023-04-15 23:10:11,765:wsdd INFO(pid 324): using pre-defined UUID cb6a33a0-b841-531d-a34e-09ecec492eb1
2023-04-15 23:10:11,767:wsdd INFO(pid 324): joined multicast group ('239.255.255.250', 3702) on 192.168.1.100%enp1s0
2023-04-15 23:10:11,770:wsdd INFO(pid 324): scheduling Hello message via enp1s0 to ('239.255.255.250', 3702)
2023-04-15 23:10:11,775:wsdd INFO(pid 324): joined multicast group ('ff02::c', 3702, 22364, 2) on fe80::8564:6432:75d6:22ee%enp1s0
2023-04-15 23:10:11,776:wsdd INFO(pid 324): scheduling Hello message via enp1s0 to ('ff02::c', 3702, 22364, 2)
2023-04-15 23:10:11,792:wsdd INFO(pid 324): 192.168.1.30 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 23:10:11,793:wsdd INFO(pid 324): 192.168.1.30 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 23:10:11,797:wsdd INFO(pid 324): fe80::5bc:a3e3:d9d8:dc57 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
2023-04-15 23:10:11,799:wsdd INFO(pid 324): fe80::5bc:a3e3:d9d8:dc57 - - "POST /cb6a33a0-b841-531d-a34e-09ecec492eb1 HTTP/1.1" 200 -
s6-rc: info: service init-mqtt successfully started
s6-rc: info: service mqtt-disk-handler: starting
s6-rc: info: service mqtt-disk-handler successfully started
s6-rc: info: service mqtt-handler: starting
s6-rc: info: service mqtt-handler successfully started
[23:10:12] INFO: Starting the MQTT daemon for disks info...
[23:10:12] INFO: Starting the MQTT daemon for partitions info...
[23:10:12] INFO: MQTT integration
Samba name server HOMEASSISTANT is now a local master browser for workgroup DOMEK on subnet 192.168.1.100
dostep ,do dysku jest
oczywiscie nie moze byc za fajnie i po przywracaniu backupow mam takie cos
pomimo ze dodatek działa (po restarcie jest ot samo)
po kliknięciu uruchom
23-04-16 00:17:23 WARNING (MainThread) [supervisor.addons.addon] 1a32f091_sambanas is already running!
Czasami zdarza się ze dodatek działa (Przywracanie z kopii ) ale nie można go zatrzymać ani uruchomić.
Spróbuj tak:
Ustawienia ⇨ System ⇨ ikonka w prawym górnym rogu Uruchom ponownie Home Assistanta Opcje zaawansowane.
Wyłącz system. Różni się to od normalnego wyłączenia przyciskiem czy restartu że wszystkie kontenery są zatrzymywane i zapisywany jest ich stan. Odczekaj chwilę i włącz ponownie sprzęt.
O dzięki to było to przyda się jak kiedyś cos takiego mi się wywali.
Ja zrobiłem 3 opcje ale nie pomagało
Śledziłem ten wątek i jako że mam wolnego pena usb podłączyłem go sobie do swojego HA.
Z poziomu windowsa go widzę, mogę sobie wrzucić na niego “coś”, natomiast nie wiem jak sprawić żeby ten dodany pendrive był widoczny w Media w HA.
https://forum.arturhome.pl/t/sharowanie-miejsca-z-wlozonego-usb-pendrive/363
Cześć
czy Samba nas działa poprawnie na HA OS 10.1
U mnie działa na Rpi3B+.
Home Assistant Supervisor
System operacyjny hosta	Home Assistant OS 10.1
Kanał aktualizacji	stable
Wersja Supervisora	supervisor-2023.04.1
Wersja agenta	1.5.1
Wersja Dockera	23.0.3
Pojemność dysku	28.5 GB
Pojemność użyta	8.9 GB
Zdrowy	true
Wspierany	true
Układ	rpi3-64
API Supervisora	ok
Wersja API	ok
Zainstalowane dodatki	File editor (5.6.0), Mosquitto broker (6.2.1), Node-RED (14.1.5), Samba share (10.0.1), SSH & Web Terminal (13.1.0), ESPHome (2023.4.2), SQLite Web (3.7.1), Zigbee2MQTT (1.30.3-1), Samba Backup (5.2.0), Samba NAS (10.0.0-nas8)
Czy zdarza Wam się, że podfoldery przestają być widoczne. Do czasu ponownego restartu?
Ja mam to z częstotliwością co najmniej codziennie. Gdzie może być problem? Czy po prostu “ten typ tak ma”?
